different results for ST_Relate with 3 parameters compared to those for ST_Relate with 2 parameters
Antonio Valanzano
anvalanz at gmail.com
Wed Oct 15 09:22:05 PDT 2025
I am following the "Introduction to PostGIS " tutorial at
https://postgis.net/workshops/postgis-intro/
and for chapter 26 "Dimensionally Extended 9-Intersection Model" I am
trying to replicate the examples.
If I use the two different versions of ST_Relate I do not obtain the same
result
SELECT
d.id,
ST_Relate(d.geom, l.geom) as patternMatrix
FROM docks as d, lakes as l
WHERE ST_Relate(d.geom, l.geom, '1FF00F212') = true;
-- 1 row
"id" "patternmatrix"
1 "1FF00F212"
SELECT
d.id,
WHERE ST_Relate(d.geom, l.geom) = '1FF00F212';
-- 2 rows
1 "1FF00F212"
2 "1FF00F212"
Could someone give me an explanation of such a difference ?
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20251015/cdf28da0/attachment.htm>
