different results for ST_Relate with 3 parameters compared to those for ST_Relate with 2 parameters
Paul Ramsey
pramsey at cleverelephant.ca
Wed Oct 15 10:28:25 PDT 2025
Maybe you have found an old bug? Running exactly the same SQL as you, I get
two rows from each query.
postgis=# SELECT
d.id,
ST_Relate(d.geom, l.geom) as patternMatrix
FROM docks as d, lakes as l
WHERE ST_Relate(d.geom, l.geom,
'1FF00F212');
id | patternmatrix
1 | 1FF00F212
2 | 1FF00F212
(2 rows)
postgis=# SELECT
postgis-# d.id,
postgis-# ST_Relate(d.geom, l.geom) as patternMatrix
postgis-# FROM docks as d, lakes as l
postgis-# WHERE ST_Relate(d.geom, l.geom) = '1FF00F212';
id | patternmatrix
1 | 1FF00F212
2 | 1FF00F212
(2 rows)
postgis=#
postgis=# select postgis_full_version();
POSTGIS="3.7.0dev 3.6.0rc2-134-g5dc95f1bc" [EXTENSION] PGSQL="180"
GEOS="3.15.0dev-CAPI-1.21.0" PROJ="9.6.2 NETWORK_ENABLED=ON URL_ENDPOINT=
https://cdn.proj.org
USER_WRITABLE_DIRECTORY=/Users/pramsey/Library/Application Support/proj
DATABASE_PATH=/opt/homebrew/Cellar/proj/9.6.2/share/proj/proj.db" (compiled
against PROJ 9.6.2) LIBXML="2.9.13" LIBJSON="0.18" LIBPROTOBUF="1.5.2"
WAGYU="0.5.0 (Internal)" (core procs from "3.7.0dev
3.6.0rc2-125-g747d7732b" need upgrade)
On Wed, Oct 15, 2025 at 9:22 AM Antonio Valanzano <anvalanz at gmail.com>
wrote:
> I am following the "Introduction to PostGIS " tutorial at
> https://postgis.net/workshops/postgis-intro/
> and for chapter 26 "Dimensionally Extended 9-Intersection Model" I am
> trying to replicate the examples.
> If I use the two different versions of ST_Relate I do not obtain the same
> result
> SELECT
> d.id,
> WHERE ST_Relate(d.geom, l.geom, '1FF00F212') = true;
> -- 1 row
> "id" "patternmatrix"
> 1 "1FF00F212"
> SELECT
> d.id,
> -- 2 rows
> 1 "1FF00F212"
> 2 "1FF00F212"
> Could someone give me an explanation of such a difference ?
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20251015/676c6a3f/attachment.htm>
