Wrong SFCGAL version used for compiling PostGIS 3.6.0 on Ubuntu?
Scott
public at postholer.com
Wed Sep 3 10:34:17 PDT 2025
Hey Greg,
Thank you for the response!
I've rolled everything back to 3.5.3 with libgeos 3.11, until I get a
better understanding.
Postgis configure is robust and allows you to set/unset all sorts of
things, including rpath. Mine looks like:
./configure \
--prefix=/export/gis/local \
--with-gdalconfig=/export/path/bin/gdal-config \
--with-geosconfig=/export/path/bin/geos-config \
--with-pgconfig=/usr/lib/postgresql/15/bin/pg_config \
--with-sfcgal=/export/path/bin/sfcgal-config
The problem is the environment. When I do an ldd on the newly built
postgis-3.so, all the paths are correct *if* in my user environment.
From another user, the paths default to the system pkg path where the
older geos 3.11 version is installed.
That's what I'm trying to understand, getting postgres/postgis to use
the correct lib it's built against.
Thanks again!
Scott
On 9/3/25 10:12, Marco Boeringa wrote:
> Well, it might also be a similar situation as with GEOS, and where I
> essenially need to wait for the next LTS release (to which I would like
> to stick and not custom compile myself), before I can benefit from the
> latest functionality with an updated SFCGAL.
> But I was just wondering, as the situation appears slightly different in
> the sense that SFCGAL has its own PostgreSQL extension contrary to GEOS,
> so the setup and situation differs at least partially.
> Greg Troxel <gdt at lexort.com> schreef op 3 september 2025 17:17:54 CEST:
> Marco Boeringa <marco at boeringa.demon.nl> writes:
> Hi,
> I noticed 3.6.0 became available on Ubuntu 24.04 where I am
> currently
> running my PostgreSQL / PostGIS install.
> Is this is a possible error during the packaging for the latest
> release for Ubuntu?
> Yes, it seems quite possible :-)
> I would suggest raising this within Ubuntu, as it seems far more likely
> to be an Ubuntu packaging issue than a postgis (source release) issue.
> You might also see which version of SFCGAL is installed on your system,
> and what the dependency specification is for the postgis package.
