Wrong SFCGAL version used for compiling PostGIS 3.6.0 on Ubuntu?
Marco Boeringa marco at boeringa.demon.nl
Wed Sep 3 10:12:42 PDT 2025
Well, it might also be a similar situation as with GEOS, and where I essenially need to wait for the next LTS release (to which I would like to stick and not custom compile myself), before I can benefit from the latest functionality with an updated SFCGAL.
But I was just wondering, as the situation appears slightly different in the sense that SFCGAL has its own PostgreSQL extension contrary to GEOS, so the setup and situation differs at least partially.
Greg Troxel <gdt at lexort.com> schreef op 3 september 2025 17:17:54 CEST:
>Marco Boeringa <marco at boeringa.demon.nl> writes:
>> Hi,
>> I noticed 3.6.0 became available on Ubuntu 24.04 where I am currently
>> running my PostgreSQL / PostGIS install.
>> Is this is a possible error during the packaging for the latest
>> release for Ubuntu?
>Yes, it seems quite possible :-)
>I would suggest raising this within Ubuntu, as it seems far more likely
>to be an Ubuntu packaging issue than a postgis (source release) issue.
>You might also see which version of SFCGAL is installed on your system,
>and what the dependency specification is for the postgis package.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20250903/70e82698/attachment.htm>
