backend error after upgrading to 3.6.0
Regina Obe lr at pcorp.us
Tue Sep 16 08:45:27 PDT 2025
We don’t distribute postgis binaries for Debian/ubuntu systems.  That is done by apt.postgresql.org.  So they would need to make the change if any change needs made.
I think PostGIS works fine with any LLVM but it sounds like maybe PostGIS was compiled with  LLVM 14 and you have 15 installed.
That should be brought up on https://www.postgresql.org/list/pgsql-pkg-debian/ mailing list or it could just be a conflict with some other stuff you have installed that could be remedied switching apt priority settings.
From: Ярослав Минин via postgis-users <postgis-users at lists.osgeo.org>
Sent: Tuesday, September 16, 2025 6:49 AM
To: postgis-users <postgis-users at lists.osgeo.org>
Subject: backend error after upgrading to 3.6.0
I guess I found the issue. Seems like every time I send queries using PostGIS functions I get the following error:
error: Not an int attribute (Producer: 'LLVM15.0.7' Reader: 'LLVM 14.0.0')
The very first time it appeared is after upgrading PostGIS to 3.6.0. LLVM on my PostgreSQL instance is 'LLVM_CONFIG=/usr/bin/llvm-config-15'.
Is it possible to make PostGIS 3.6.0 use LLVM 15?
P.S. Sorry for previously sending letters privately. It was by mistake.
Sincerely,
Yaras
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20250916/4d1b648f/attachment.htm>
