Re: RE: backend error after upgrading to 3.6.0
Ярослав Минин
yaras_phoenix at inbox.ru
Tue Sep 16 10:44:16 PDT 2025
Didn't see the last message.
Thanks for the hint, I'll give it a try on other mailing list.
вторник, 16 сентября 2025г., 17:45 +02:00 от Regina Obe lr at pcorp.us :
>We don’t distribute postgis binaries for Debian/ubuntu systems. That is done by apt.postgresql.org. So they would need to make the change if any change needs made.
>I think PostGIS works fine with any LLVM but it sounds like maybe PostGIS was compiled with LLVM 14 and you have 15 installed.
>That should be brought up on https://www.postgresql.org/list/pgsql-pkg-debian/ mailing list or it could just be a conflict with some other stuff you have installed that could be remedied switching apt priority settings.
>From: Ярослав Минин via postgis-users < postgis-users at lists.osgeo.org>
>Sent: Tuesday, September 16, 2025 6:49 AM
>To: postgis-users < postgis-users at lists.osgeo.org>
>Subject: backend error after upgrading to 3.6.0
>I guess I found the issue. Seems like every time I send queries using PostGIS functions I get the following error:
>error: Not an int attribute (Producer: 'LLVM15.0.7' Reader: 'LLVM 14.0.0')
>The very first time it appeared is after upgrading PostGIS to 3.6.0. LLVM on my PostgreSQL instance is 'LLVM_CONFIG=/usr/bin/llvm-config-15' .
>Is it possible to make PostGIS 3.6.0 use LLVM 15?
>P.S. Sorry for previously sending letters privately. It was by mistake.
>Sincerely,
>Yaras
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20250916/7b6a8a10/attachment.htm>
