PG_Restore error
Regina Obe lr at pcorp.us
Tue Feb 10 03:48:37 PST 2026
Not sure what you mean by unintentionally dumped as binary format.  That is the preferred way.
What you should do is the following:
Create a blank database.
Run
CREATE EXTENSION postgis;
CREATE EXTENSION postgis_raster;
Then restore your database into the new one you created.
The only thing that should happen assuming you have an individual backup for your database, is that it will failing when doing CREATE EXTENSION postgis;  which is fine and expected.
But your raster data will find the datatype and functions it needs in postgis_raster so should do fine.
Sent: Tuesday, February 10, 2026 1:28 AM
To: postgis-users at lists.osgeo.org
Subject: PG_Restore error
Hello,
I have an old PostgreSQL database dump file that uses the old PostGIS extension. What I mean is that the database was created when the extension used to be CREATE Extension PostGIS. Now there are at least 2 commands: CREATE Extension postgis and  CREATE Extension postgis_raster; This particular database has both vector and raster datasets. To complicate matters, I unintentionally dumped it in a binary format.
I have been somewhat successful in getting the DB to load. I'm using a pg_restore command using the following flags (--no-owner --create --clean). However, I get a lot of errors because the database can not create raster datasets as that datatype does not exist. Is there a command that I can issue during this pg_restore process to initialize the postgis_raster extension? If not, what are my next steps? Do I need to load the database onto an older version of PostGIS?
Thanks for any feedback
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20260210/4624ddb4/attachment.htm>
