PG_Restore error
David Haynes haynesd2 at gmail.com
Wed Feb 11 08:02:26 PST 2026
Thanks for the help. Can you provide me with the flags I should use on
PG_Restore.
On Tue, Feb 10, 2026 at 5:48 AM Regina Obe <lr at pcorp.us> wrote:
> Not sure what you mean by unintentionally dumped as binary format.  That
> is the preferred way.
> What you should do is the following:
> Create a blank database.
> Run
> CREATE EXTENSION postgis;
> CREATE EXTENSION postgis_raster;
> Then restore your database into the new one you created.
> The only thing that should happen assuming you have an individual backup
> for your database, is that it will failing when doing CREATE EXTENSION
> postgis;  which is fine and expected.
> But your raster data will find the datatype and functions it needs in
> postgis_raster so should do fine.
> *From:* David Haynes <haynesd2 at gmail.com>
> *Sent:* Tuesday, February 10, 2026 1:28 AM
> *To:* postgis-users at lists.osgeo.org
> *Subject:* PG_Restore error
> Hello,
> I have an old PostgreSQL database dump file that uses the old PostGIS
> extension. What I mean is that the database was created when the extension
> used to be CREATE Extension PostGIS. Now there are at least 2 commands:
> CREATE Extension postgis and  CREATE Extension postgis_raster; This
> particular database has both vector and raster datasets. To complicate
> matters, I unintentionally dumped it in a binary format.
> I have been somewhat successful in getting the DB to load. I'm using a
> pg_restore command using the following flags (--no-owner --create --clean).
> However, I get a lot of errors because the database can not create raster
> datasets as that datatype does not exist. Is there a command that I can
> issue during this pg_restore process to initialize the postgis_raster
> extension? If not, what are my next steps? Do I need to load the database
> onto an older version of PostGIS?
> Thanks for any feedback
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20260211/efff0d98/attachment.htm>
