PG_Restore error
Richard Greenwood
richard.greenwood at gmail.com
Wed Feb 11 12:01:08 PST 2026
You probably don't need any flags beyond specifying the target database
name. Follow Regina instructions: create a target database and add postgis
and postgis_raster extensions to it. The run pg_restore like:
pg_restore -d target_database_name your_pg_dump_file.backup
Postgres error messages are usually pretty clear so if that doesn't work it
will probably tell you why.
Rich
On Wed, Feb 11, 2026 at 9:41 AM David Haynes <haynesd2 at gmail.com> wrote:
> Thanks for the help. Can you provide me with the flags I should use on
> PG_Restore.
> On Tue, Feb 10, 2026 at 5:48 AM Regina Obe <lr at pcorp.us> wrote:
>> Not sure what you mean by unintentionally dumped as binary format. That
>> is the preferred way.
>> What you should do is the following:
>> Create a blank database.
>> Run
>> CREATE EXTENSION postgis;
>> CREATE EXTENSION postgis_raster;
>> Then restore your database into the new one you created.
>> The only thing that should happen assuming you have an individual backup
>> for your database, is that it will failing when doing CREATE EXTENSION
>> postgis; which is fine and expected.
>> But your raster data will find the datatype and functions it needs in
>> postgis_raster so should do fine.
>> *From:* David Haynes <haynesd2 at gmail.com>
>> *Sent:* Tuesday, February 10, 2026 1:28 AM
>> *To:* postgis-users at lists.osgeo.org
>> *Subject:* PG_Restore error
>> Hello,
>> I have an old PostgreSQL database dump file that uses the old PostGIS
>> extension. What I mean is that the database was created when the extension
>> used to be CREATE Extension PostGIS. Now there are at least 2 commands:
>> CREATE Extension postgis and CREATE Extension postgis_raster; This
>> particular database has both vector and raster datasets. To complicate
>> matters, I unintentionally dumped it in a binary format.
>> I have been somewhat successful in getting the DB to load. I'm using a
>> pg_restore command using the following flags (--no-owner --create --clean).
>> However, I get a lot of errors because the database can not create raster
>> datasets as that datatype does not exist. Is there a command that I can
>> issue during this pg_restore process to initialize the postgis_raster
>> extension? If not, what are my next steps? Do I need to load the database
>> onto an older version of PostGIS?
>> Thanks for any feedback
Richard W. Greenwood
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20260211/a7f0a90e/attachment.htm>
