PostGIS 3.6.1 - ERROR: operator is not unique: public.geometry = public.geometry
Cedric Duprez
cedric.duprez at ign.fr
Thu Jan 8 08:20:58 PST 2026
Hi all,
I'm facing a potential bug with PostGIS 3.6.1 on PostgreSQL 17.7.
Here is what I get with postgis_full_version() : POSTGIS="3.6.1
f533623" [EXTENSION] PGSQL="170" GEOS="3.12.1-CAPI-1.18.1" PROJ="9.4.0
NETWORK_ENABLED=OFF URL_ENDPOINT=https://cdn.proj.org
USER_WRITABLE_DIRECTORY=/tmp/proj DATABASE_PATH=/usr/share/proj/proj.db"
(compiled against PROJ 9.4.0) GDAL="GDAL 3.8.4, released 2024/02/08"
LIBXML="2.9.14" LIBJSON="0.17" LIBPROTOBUF="1.4.1" WAGYU="0.5.0
(Internal)" RASTER
When I execute this query:
SELECT 'POINT EMPTY'::public.geometry = 'POINT EMPTY'::public.geometry;
I get the following error:
It seems to be a regression, since I didn't have this error on previous
versions of PostGIS (3.5).
How can this problem be solved?
Thanks in advance for you help,
Cedric
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20260108/26e63058/attachment.htm>
