PostGIS 3.6.1 - ERROR: operator is not unique: public.geometry = public.geometry
Paul Ramsey pramsey at cleverelephant.ca
Thu Jan 8 08:25:48 PST 2026
This is odd, I am not able to replicate...
 POSTGIS="3.6.1dev 3.6.0-6-gdb18a9a49" PGSQL="180"
GEOS="3.15.0dev-CAPI-1.21.0" PROJ="9.3.0 NETWORK_ENABLED=ON URL_ENDPOINT=
https://cdn.proj.org
USER_WRITABLE_DIRECTORY=/Users/pramsey/Library/Application Support/proj
DATABASE_PATH=/usr/local/share/proj/proj.db" (compiled against PROJ 9.3.0)
LIBXML="2.9.13" LIBJSON="0.17" LIBPROTOBUF="1.4.1" WAGYU="0.5.0 (Internal)"
(1 row)
postgis_reg=# SELECT 'POINT EMPTY'::public.geometry = 'POINT
EMPTY'::public.geometry;
 ?column?
 t
(1 row)
Is this a database that has gone through upgrade stages, or a blank fresh
database?
P
On Thu, Jan 8, 2026 at 8:21 AM Cedric Duprez <cedric.duprez at ign.fr> wrote:
> Hi all,
> I'm facing a potential bug with PostGIS 3.6.1 on PostgreSQL 17.7.
> Here is what I get with postgis_full_version() :  POSTGIS="3.6.1 f533623"
> [EXTENSION] PGSQL="170" GEOS="3.12.1-CAPI-1.18.1" PROJ="9.4.0
> NETWORK_ENABLED=OFF URL_ENDPOINT=https://cdn.proj.org
> USER_WRITABLE_DIRECTORY=/tmp/proj DATABASE_PATH=/usr/share/proj/proj.db"
> (compiled against PROJ 9.4.0) GDAL="GDAL 3.8.4, released 2024/02/08"
> LIBXML="2.9.14" LIBJSON="0.17" LIBPROTOBUF="1.4.1" WAGYU="0.5.0 (Internal)"
> RASTER
> When I execute this query:
> SELECT 'POINT EMPTY'::public.geometry = 'POINT EMPTY'::public.geometry;
> I get the following error:
> It seems to be a regression, since I didn't have this error on previous
> versions of PostGIS (3.5).
> How can this problem be solved?
> Thanks in advance for you help,
> Cedric
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20260108/10cd2eed/attachment.htm>
