PostGIS 3.6.1 - ERROR: operator is not unique: public.geometry = public.geometry
Cedric Duprez
cedric.duprez at ign.fr
Thu Jan 8 08:52:33 PST 2026
Hi Paul,
Thanks for your answer.
The database was restored from a cold physical backup (PGDATA copy).
Cedric
Le 08/01/2026 à 17:25, Paul Ramsey a écrit :
> This is odd, I am not able to replicate...
> POSTGIS="3.6.1dev 3.6.0-6-gdb18a9a49" PGSQL="180"
> GEOS="3.15.0dev-CAPI-1.21.0" PROJ="9.3.0 NETWORK_ENABLED=ON
> URL_ENDPOINT=https://cdn.proj.org
> USER_WRITABLE_DIRECTORY=/Users/pramsey/Library/Application
> Support/proj DATABASE_PATH=/usr/local/share/proj/proj.db" (compiled
> against PROJ 9.3.0) LIBXML="2.9.13" LIBJSON="0.17" LIBPROTOBUF="1.4.1"
> WAGYU="0.5.0 (Internal)"
> (1 row)
> postgis_reg=# SELECT 'POINT EMPTY'::public.geometry = 'POINT
> EMPTY'::public.geometry;
> ?column?
> t
> (1 row)
> Is this a database that has gone through upgrade stages, or a blank
> fresh database?
> P
> On Thu, Jan 8, 2026 at 8:21 AM Cedric Duprez <cedric.duprez at ign.fr> wrote:
> Hi all,
> I'm facing a potential bug with PostGIS 3.6.1 on PostgreSQL 17.7.
> Here is what I get with postgis_full_version() : POSTGIS="3.6.1
> f533623" [EXTENSION] PGSQL="170" GEOS="3.12.1-CAPI-1.18.1"
> PROJ="9.4.0 NETWORK_ENABLED=OFF URL_ENDPOINT=https://cdn.proj.org
> USER_WRITABLE_DIRECTORY=/tmp/proj
> DATABASE_PATH=/usr/share/proj/proj.db" (compiled against PROJ
> 9.4.0) GDAL="GDAL 3.8.4, released 2024/02/08" LIBXML="2.9.14"
> LIBJSON="0.17" LIBPROTOBUF="1.4.1" WAGYU="0.5.0 (Internal)" RASTER
> When I execute this query:
> I get the following error:
> It seems to be a regression, since I didn't have this error on
> previous versions of PostGIS (3.5).
> How can this problem be solved?
> Thanks in advance for you help,
> Cedric
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20260108/beada132/attachment.htm>
