PostGIS 3.6.1 - ERROR: operator is not unique: public.geometry = public.geometry
Arthur Bazin arthurbazin at gmail.com
Thu Jan 8 08:54:46 PST 2026
@paul, you have not the exact same version of PostGIS and therefore of GEOS
and PROJ.
Maybe the origin of the non reproductibility ?
Best regards
Arthur
Le jeu. 8 janv. 2026, 17:26, Paul Ramsey via postgis-users <
postgis-users at lists.osgeo.org> a écrit :
> This is odd, I am not able to replicate...
>  POSTGIS="3.6.1dev 3.6.0-6-gdb18a9a49" PGSQL="180"
> GEOS="3.15.0dev-CAPI-1.21.0" PROJ="9.3.0 NETWORK_ENABLED=ON URL_ENDPOINT=
> https://cdn.proj.org
> USER_WRITABLE_DIRECTORY=/Users/pramsey/Library/Application Support/proj
> DATABASE_PATH=/usr/local/share/proj/proj.db" (compiled against PROJ 9.3.0)
> LIBXML="2.9.13" LIBJSON="0.17" LIBPROTOBUF="1.4.1" WAGYU="0.5.0 (Internal)"
> (1 row)
> postgis_reg=# SELECT 'POINT EMPTY'::public.geometry = 'POINT
> EMPTY'::public.geometry;
>  ?column?
>  t
> (1 row)
> Is this a database that has gone through upgrade stages, or a blank fresh
> database?
> P
> On Thu, Jan 8, 2026 at 8:21 AM Cedric Duprez <cedric.duprez at ign.fr> wrote:
>> Hi all,
>> I'm facing a potential bug with PostGIS 3.6.1 on PostgreSQL 17.7.
>> Here is what I get with postgis_full_version() :  POSTGIS="3.6.1 f533623"
>> [EXTENSION] PGSQL="170" GEOS="3.12.1-CAPI-1.18.1" PROJ="9.4.0
>> NETWORK_ENABLED=OFF URL_ENDPOINT=https://cdn.proj.org
>> USER_WRITABLE_DIRECTORY=/tmp/proj DATABASE_PATH=/usr/share/proj/proj.db"
>> (compiled against PROJ 9.4.0) GDAL="GDAL 3.8.4, released 2024/02/08"
>> LIBXML="2.9.14" LIBJSON="0.17" LIBPROTOBUF="1.4.1" WAGYU="0.5.0 (Internal)"
>> RASTER
>> When I execute this query:
>> SELECT 'POINT EMPTY'::public.geometry = 'POINT EMPTY'::public.geometry;
>> I get the following error:
>> It seems to be a regression, since I didn't have this error on previous
>> versions of PostGIS (3.5).
>> How can this problem be solved?
>> Thanks in advance for you help,
>> Cedric
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20260108/97caee63/attachment.htm>
