PostGIS 3.7.0rc3 release
Greg Troxel gdt at lexort.com
Wed Oct 21 16:18:13 PDT 2026
"Regina Obe" <lr at pcorp.us> writes:
> The PostGIS Team is pleased to release PostGIS 3.7.0rc3! Best Served with
> PostgreSQL 19 RC1 , GEOS 3.15.0 ,
> This version requires PostgreSQL 14 - 19rc1, GEOS 3.10 or higher, and Proj
> 6.1+. To take advantage of all features, GEOS 3.15+ is needed. To take
> advantage of all SFCGAL features SFCGAL 2.3.0+ is needed.
This builds and mostly passes tests on NetBSD 11 amd64.
The tests fail with what is obviously test environment assumptions
problems:
  RUNTESTFLAGS:  --topology --raster
  RUNTESTFLAGS_INTERNAL: --after-create-db-script ../raster/test/regress/hooks/hook-before-create-raster.sql --before-upgrade-script ../raster/test/regress/hooks/hook-before-upgrade-raster.sql --before-upgrade-script ../topology/test/regress/hooks/hook-before-upgrade-topology.sql --after-create-db-script ../regress/hooks/hook-after-create-db.sql --before-upgrade-script ../regress/hooks/hook-before-upgrade.sql --after-upgrade-script ../regress/hooks/hook-after-upgrade-check-sql-object-resolution.sql --after-upgrade-script ../regress/hooks/hook-after-upgrade.sql --after-create-script   ../regress/hooks/hook-after-create.sql --before-uninstall-script ../regress/hooks/hook-before-uninstall.sql --after-upgrade-script ../topology/test/regress/hooks/hook-after-upgrade-topology.sql --after-upgrade-script ../raster/test/regress/hooks/hook-after-upgrade-raster.sql
  psql: error: connection to server on socket "/tmp/.s.PGSQL.5432" failed: FATAL:  permission denied to set parameter "lc_messages"
  Creating database 'postgis_reg-3.7'.
  Running after-create-db-script ../raster/test/regress/hooks/hook-before-create-raster.sql
  Died at ../regress/run_test.pl line 1568.
   failed (Error encountered loading ../raster/test/regress/hooks/hook-before-create-raster.sql: /tmp/pgis_reg/regress_log.tmp)
  gmake: *** [../regress/runtest.mk:24: check-regress] Error 2
I do have my postgresql locked down more than many, but README.postgis
doesn't say what's needed.  (I'm not a superuser.)
There is a large amount of ctype UB.  I don't know if this is new, but I
think I would have noticed and said something.
Briefly, ctype functions take an int, and are defined only for values
that are valid for unsigned char or EOF.  Everything else is UB.
Calling them with a variable of type char, if char is signed, leads to
negative values.  I would expect at least some systems in CI to warn
somehow, but maybe they don't.
libtool: compile:  gcc -I../../liblwgeom/../deps/ryu/.. -I/usr/pkg/include -I/usr/pkg/include -I/usr/pkg/include -I/usr/pkg/include/libxml2 -I/usr/pkg/include -I/usr/pkg/include -I/usr/pkg/include/json-c -DNDEBUG -I. -I../../liblwgeom -std=gnu11 -g -O2 -fno-math-errno -fno-signed-zeros -Wall -O2 -fPIC -DPIC -c ../../liblwgeom/optionlist.c  -fPIC -DPIC -o .libs/optionlist.o
In file included from /usr/include/ctype.h:100,
                 from ../../liblwgeom/optionlist.c:28:
../../liblwgeom/optionlist.c: In function 'option_list_string_to_lower':
../../liblwgeom/optionlist.c:36:32: warning: array subscript has type 'char' [-Wchar-subscripts]
   36 |                 *key = tolower(*key);
libtool: compile:  gcc -I../../liblwgeom/../deps/ryu/.. -I/usr/pkg/include -I/usr/pkg/include -I/usr/pkg/include -I/usr/pkg/include/libxml2 -I/usr/pkg/include -I/usr/pkg/include -I/usr/pkg/include/json-c -DNDEBUG -I. -I../../liblwgeom -std=gnu11 -g -O2 -fno-math-errno -fno-signed-zeros -Wall -O2 -fPIC -DPIC -c lwin_wkt_lex.c  -fPIC -DPIC -o .libs/lwin_wkt_lex.o
                 from ../../liblwgeom/lwin_wkt_lex.l:5:
../../liblwgeom/lwin_wkt_lex.l: In function 'wkt_yylex':
../../liblwgeom/lwin_wkt_lex.l:108:31: warning: array subscript has type 'char' [-Wchar-subscripts]
  108 |         if (toupper(wkt_yytext[0]) == 'Z' && toupper(wkt_yytext[1]) == 'M')
../../liblwgeom/lwin_wkt_lex.l:108:64: warning: array subscript has type 'char' [-Wchar-subscripts]
../../liblwgeom/lwin_wkt_lex.l:110:36: warning: array subscript has type 'char' [-Wchar-subscripts]
  110 |         else if (toupper(wkt_yytext[0]) == 'Z')
libtool: compile:  gcc -I../../liblwgeom/../deps/ryu/.. -I/usr/pkg/include -I/usr/pkg/include -I/usr/pkg/include -I/usr/pkg/include/libxml2 -I/usr/pkg/include -I/usr/pkg/include -I/usr/pkg/include/json-c -DNDEBUG -I. -I../../liblwgeom -std=gnu11 -g -O2 -fno-math-errno -fno-signed-zeros -Wall -O2 -fPIC -DPIC -c ../../liblwgeom/lwin_wkt.c  -fPIC -DPIC -o .libs/lwin_wkt.o
                 from ../../liblwgeom/lwin_wkt.c:27:
../../liblwgeom/lwin_wkt.c: In function 'wkt_dimensionality':
../../liblwgeom/lwin_wkt.c:91:50: warning: array subscript has type 'char' [-Wchar-subscripts]
   91 |                 else if( ! isspace(dimensionality[i]) ) break;
libtool: compile:  gcc -I../../liblwgeom/../deps/ryu/.. -I/usr/pkg/include -I/usr/pkg/include -I/usr/pkg/include -I/usr/pkg/include/libxml2 -I/usr/pkg/include -I/usr/pkg/include -I/usr/pkg/include/json-c -DNDEBUG -I. -I../../liblwgeom -std=gnu11 -g -O2 -fno-math-errno -fno-signed-zeros -Wall -O2 -fPIC -DPIC -c ../../liblwgeom/lwalgorithm.c  -fPIC -DPIC -o .libs/lwalgorithm.o
                 from ../../liblwgeom/lwalgorithm.c:28:
../../liblwgeom/lwalgorithm.c: In function 'decode_geohash_bbox':
../../liblwgeom/lwalgorithm.c:699:41: warning: array subscript has type 'char' [-Wchar-subscripts]
  699 |                 char c = tolower(geohash[i]);
gcc -Wall -Wmissing-prototypes -Wpointer-arith -Wdeclaration-after-statement -Werror=vla -Wendif-labels -Wmissing-format-attribute -Wimplicit-fallthrough=3 -Wcast-function-type -Wshadow=compatible-local -Wformat-security -fno-strict-aliasing -fwrapv -fexcess-precision=standard -Wno-format-truncation -Wno-stringop-truncation -O2 -I/usr/include -I/usr/pkg/include/libxml2 -I/usr/include/readline -I/usr/pkg/include -std=gnu11 -g -O2 -fno-math-errno -fno-signed-zeros -Wall -O2  -fno-semantic-interposition  -fPIC -DPIC -fPIC -DPIC -fvisibility=hidden -I../../liblwgeom -I../liblwgeom -I../../libpgcommon -I../../deps/flatgeobuf -I../../deps/wagyu -I../../deps/uthash/include  -I/usr/pkg/include -I/usr/pkg/include -I/usr/pkg/include -I/usr/pkg/include/libxml2 -I/usr/pkg/include  -I/usr/pkg/include -I/usr/pkg/include/json-c -DNDEBUG  -I. -I./ -I/usr/pkg/include/postgresql/server -I/usr/pkg/include/postgresql/internal -I/usr/include -I/usr/pkg/include/libxml2 -I/usr/include/readline -I/usr/pkg/include  -I/usr/pkg/include/libxml2 -I/usr/pkg/include -I/usr/pkg/include    -c -o lwgeom_box.o ../../postgis/lwgeom_box.c
                 from /usr/pkg/include/postgresql/server/port.h:16,
                 from /usr/pkg/include/postgresql/server/c.h:1360,
                 from /usr/pkg/include/postgresql/server/postgres.h:48,
                 from ../../postgis/lwgeom_box.c:27:
../../postgis/lwgeom_box.c: In function ‘BOX2D_in’:
../../postgis/lwgeom_box.c:68:31: warning: array subscript has type ‘char’ [-Wchar-subscripts]
   68 |           str[i] = tolower(str[i]);
gcc -Wall -Wmissing-prototypes -Wpointer-arith -Wdeclaration-after-statement -Werror=vla -Wendif-labels -Wmissing-format-attribute -Wimplicit-fallthrough=3 -Wcast-function-type -Wshadow=compatible-local -Wformat-security -fno-strict-aliasing -fwrapv -fexcess-precision=standard -Wno-format-truncation -Wno-stringop-truncation -O2 -I/usr/include -I/usr/pkg/include/libxml2 -I/usr/include/readline -I/usr/pkg/include -std=gnu11 -g -O2 -fno-math-errno -fno-signed-zeros -Wall -O2  -fno-semantic-interposition  -fPIC -DPIC -fPIC -DPIC -fvisibility=hidden -I../../liblwgeom -I../liblwgeom -I../../libpgcommon -I../../deps/flatgeobuf -I../../deps/wagyu -I../../deps/uthash/include  -I/usr/pkg/include -I/usr/pkg/include -I/usr/pkg/include -I/usr/pkg/include/libxml2 -I/usr/pkg/include  -I/usr/pkg/include -I/usr/pkg/include/json-c -DNDEBUG  -I. -I./ -I/usr/pkg/include/postgresql/server -I/usr/pkg/include/postgresql/internal -I/usr/include -I/usr/pkg/include/libxml2 -I/usr/include/readline -I/usr/pkg/include  -I/usr/pkg/include/libxml2 -I/usr/pkg/include -I/usr/pkg/include    -c -o lwgeom_in_gml.o ../../postgis/lwgeom_in_gml.c
                 from ../../postgis/lwgeom_in_gml.c:49:
../../postgis/lwgeom_in_gml.c: In function ‘parse_gml_srs’:
../../postgis/lwgeom_in_gml.c:557:38: warning: array subscript has type ‘char’ [-Wchar-subscripts]
  557 |                         if (!isdigit(*p)) gml_lwpgerror("unknown spatial reference system", 5);
../../postgis/lwgeom_in_gml.c: In function ‘parse_gml_double’:
../../postgis/lwgeom_in_gml.c:604:42: warning: array subscript has type ‘char’ [-Wchar-subscripts]
  604 |         if (space_before) while (isspace(*d)) d++;
../../postgis/lwgeom_in_gml.c:608:29: warning: array subscript has type ‘char’ [-Wchar-subscripts]
  608 |                 if (isdigit(*p))
../../postgis/lwgeom_in_gml.c:632:34: warning: array subscript has type ‘char’ [-Wchar-subscripts]
  632 |                 else if (isspace(*p))
../../postgis/lwgeom_in_gml.c: In function ‘parse_gml_coordinates’:
../../postgis/lwgeom_in_gml.c:712:24: warning: array subscript has type ‘char’ [-Wchar-subscripts]
  712 |         while (isspace(*p)) p++;                /* Eat extra whitespaces if any */
../../postgis/lwgeom_in_gml.c:716:29: warning: array subscript has type ‘char’ [-Wchar-subscripts]
  716 |                 if (isdigit(*p)) digit = true;  /* One state parser */
../../postgis/lwgeom_in_gml.c: In function ‘parse_gml_pos’:
../../postgis/lwgeom_in_gml.c:852:20: warning: array subscript has type ‘char’ [-Wchar-subscripts]
  852 |     while (isspace(*pos)) pos++;        /* Eat extra whitespaces if any */
../../postgis/lwgeom_in_gml.c:859:21: warning: array subscript has type ‘char’ [-Wchar-subscripts]
  859 |         if (isdigit(*pos)) digit = true;
../../postgis/lwgeom_in_gml.c: In function ‘parse_gml_poslist’:
../../postgis/lwgeom_in_gml.c:923:24: warning: array subscript has type ‘char’ [-Wchar-subscripts]
  923 |         while (isspace(*poslist)) poslist++;    /* Eat extra whitespaces if any */
../../postgis/lwgeom_in_gml.c:926:29: warning: array subscript has type ‘char’ [-Wchar-subscripts]
  926 |                 if (isdigit(*poslist)) digit = true;
gcc -Wall -Wmissing-prototypes -Wpointer-arith -Wdeclaration-after-statement -Werror=vla -Wendif-labels -Wmissing-format-attribute -Wimplicit-fallthrough=3 -Wcast-function-type -Wshadow=compatible-local -Wformat-security -fno-strict-aliasing -fwrapv -fexcess-precision=standard -Wno-format-truncation -Wno-stringop-truncation -O2 -I/usr/include -I/usr/pkg/include/libxml2 -I/usr/include/readline -I/usr/pkg/include -std=gnu11 -g -O2 -fno-math-errno -fno-signed-zeros -Wall -O2  -fno-semantic-interposition  -fPIC -DPIC -fPIC -DPIC -fvisibility=hidden -I../../liblwgeom -I../liblwgeom -I../../libpgcommon -I../../deps/flatgeobuf -I../../deps/wagyu -I../../deps/uthash/include  -I/usr/pkg/include -I/usr/pkg/include -I/usr/pkg/include -I/usr/pkg/include/libxml2 -I/usr/pkg/include  -I/usr/pkg/include -I/usr/pkg/include/json-c -DNDEBUG  -I. -I./ -I/usr/pkg/include/postgresql/server -I/usr/pkg/include/postgresql/internal -I/usr/include -I/usr/pkg/include/libxml2 -I/usr/include/readline -I/usr/pkg/include  -I/usr/pkg/include/libxml2 -I/usr/pkg/include -I/usr/pkg/include    -c -o lwgeom_in_kml.o ../../postgis/lwgeom_in_kml.c
                 from ../../postgis/lwgeom_in_kml.c:40:
../../postgis/lwgeom_in_kml.c: In function ‘parse_kml_coordinates’:
../../postgis/lwgeom_in_kml.c:332:24: warning: array subscript has type ‘char’ [-Wchar-subscripts]
  332 |   while (*p && isspace(*p)) ++p;
../../postgis/lwgeom_in_kml.c:336:18: warning: array subscript has type ‘char’ [-Wchar-subscripts]
  336 |     if ( isdigit(*p) || *p == '+' || *p == '-' || *p == '.' ) {
../../postgis/lwgeom_in_kml.c:353:30: warning: array subscript has type ‘char’ [-Wchar-subscripts]
  353 |         if ( *q && ! isspace(*q) && *q != ',' ) {
../../postgis/lwgeom_in_kml.c:358:30: warning: array subscript has type ‘char’ [-Wchar-subscripts]
  358 |         while (*q && isspace(*q)) ++q;
../../postgis/lwgeom_in_kml.c:359:22: warning: array subscript has type ‘char’ [-Wchar-subscripts]
  359 |         if ( isdigit(*q) || *q == '+' || *q == '-' || *q == '.' || ! *q ) {
../../postgis/lwgeom_in_kml.c:371:40: warning: array subscript has type ‘char’ [-Wchar-subscripts]
  371 |     } else if ( *p != ',' && ! isspace(*p) ) {
gcc -Wall -Wmissing-prototypes -Wpointer-arith -Wdeclaration-after-statement -Werror=vla -Wendif-labels -Wmissing-format-attribute -Wimplicit-fallthrough=3 -Wcast-function-type -Wshadow=compatible-local -Wformat-security -fno-strict-aliasing -fwrapv -fexcess-precision=standard -Wno-format-truncation -Wno-stringop-truncation -O2 -I/usr/include -I/usr/pkg/include/libxml2 -I/usr/include/readline -I/usr/pkg/include -std=gnu11 -g -O2 -fno-math-errno -fno-signed-zeros -Wall -O2  -fno-semantic-interposition  -fPIC -DPIC -fPIC -DPIC -fvisibility=hidden -I../../liblwgeom -I../liblwgeom -I../../libpgcommon -I../../deps/flatgeobuf -I../../deps/wagyu -I../../deps/uthash/include  -I/usr/pkg/include -I/usr/pkg/include -I/usr/pkg/include -I/usr/pkg/include/libxml2 -I/usr/pkg/include  -I/usr/pkg/include -I/usr/pkg/include/json-c -DNDEBUG  -I. -I./ -I/usr/pkg/include/postgresql/server -I/usr/pkg/include/postgresql/internal -I/usr/include -I/usr/pkg/include/libxml2 -I/usr/include/readline -I/usr/pkg/include  -I/usr/pkg/include/libxml2 -I/usr/pkg/include -I/usr/pkg/include    -c -o lwgeom_in_marc21.o ../../postgis/lwgeom_in_marc21.c
                 from ../../postgis/lwgeom_in_marc21.c:21:
../../postgis/lwgeom_in_marc21.c: In function ‘is_literal_valid’:
../../postgis/lwgeom_in_marc21.c:153:37: warning: array subscript has type ‘char’ [-Wchar-subscripts]
  153 |                 if (!isdigit(literal[j])) {
gmake[1]: Entering directory '/n0/gdt/SOFTWARE/GEO/POSTGIS/postgis/BUILD/topology'
gcc -Wall -Wmissing-prototypes -Wpointer-arith -Wdeclaration-after-statement -Werror=vla -Wendif-labels -Wmissing-format-attribute -Wimplicit-fallthrough=3 -Wcast-function-type -Wshadow=compatible-local -Wformat-security -fno-strict-aliasing -fwrapv -fexcess-precision=standard -Wno-format-truncation -Wno-stringop-truncation -O2 -I/usr/include -I/usr/pkg/include/libxml2 -I/usr/include/readline -I/usr/pkg/include -std=gnu11 -g -O2 -fno-math-errno -fno-signed-zeros -Wall -O2  -fno-semantic-interposition  -fPIC -DPIC -fPIC -DPIC -fvisibility=hidden -I../liblwgeom -I../../liblwgeom -I../../libpgcommon  -I/usr/pkg/include -I/usr/pkg/include -I/usr/pkg/include -I/usr/pkg/include/libxml2 -I/usr/pkg/include  -I/usr/pkg/include -I/usr/pkg/include/json-c -DNDEBUG  -I. -I../../topology -I/usr/pkg/include/postgresql/server -I/usr/pkg/include/postgresql/internal -I/usr/include -I/usr/pkg/include/libxml2 -I/usr/include/readline -I/usr/pkg/include  -I/usr/pkg/include/libxml2 -I/usr/pkg/include -I/usr/pkg/include    -c -o postgis_topology.o ../../topology/postgis_topology.c
                 from ../../topology/postgis_topology.c:14:
../../topology/postgis_topology.c: In function ‘_lwtype_upper_name’:
../../topology/postgis_topology.c:145:20: warning: array subscript has type ‘char’ [-Wchar-subscripts]
  145 |     *ptr = toupper(*ptr);
gmake[3]: Entering directory '/n0/gdt/SOFTWARE/GEO/POSTGIS/postgis/BUILD/raster/rt_pg'
gcc -Wall -Wmissing-prototypes -Wpointer-arith -Wdeclaration-after-statement -Werror=vla -Wendif-labels -Wmissing-format-attribute -Wimplicit-fallthrough=3 -Wcast-function-type -Wshadow=compatible-local -Wformat-security -fno-strict-aliasing -fwrapv -fexcess-precision=standard -Wno-format-truncation -Wno-stringop-truncation -O2 -I/usr/include -I/usr/pkg/include/libxml2 -I/usr/include/readline -I/usr/pkg/include -std=gnu11 -g -O2 -fno-math-errno -fno-signed-zeros -Wall -O2  -fno-semantic-interposition -fPIC -DPIC -fvisibility=hidden -I../../../liblwgeom -I../../liblwgeom -I/usr/pkg/include -I/usr/pkg/include -I/usr/pkg/include -I/usr/pkg/include/libxml2 -I/usr/pkg/include  -I/usr/pkg/include -I/usr/pkg/include/json-c -DNDEBUG -I/usr/pkg/include -I../../../libpgcommon -I/usr/pkg/include -I../../../raster/rt_pg/../rt_core -I. -I./.. -I../.. -I. -I./ -I/usr/pkg/include/postgresql/server -I/usr/pkg/include/postgresql/internal -I/usr/include -I/usr/pkg/include/libxml2 -I/usr/include/readline -I/usr/pkg/include  -I/usr/pkg/include/libxml2 -I/usr/pkg/include -I/usr/pkg/include    -c -o rtpostgis.o ../../../raster/rt_pg/rtpostgis.c
                 from ../../../raster/rt_pg/rtpostgis.c:132:
../../../raster/rt_pg/rtpostgis.c: In function ‘rt_pg_vsi_load_options’:
../../../raster/rt_pg/rtpostgis.c:400:48: warning: array subscript has type ‘char’ [-Wchar-subscripts]
  400 |                                 *ptr = tolower(*ptr);
gcc -Wall -Wmissing-prototypes -Wpointer-arith -Wdeclaration-after-statement -Werror=vla -Wendif-labels -Wmissing-format-attribute -Wimplicit-fallthrough=3 -Wcast-function-type -Wshadow=compatible-local -Wformat-security -fno-strict-aliasing -fwrapv -fexcess-precision=standard -Wno-format-truncation -Wno-stringop-truncation -O2 -I/usr/include -I/usr/pkg/include/libxml2 -I/usr/include/readline -I/usr/pkg/include -std=gnu11 -g -O2 -fno-math-errno -fno-signed-zeros -Wall -O2  -fno-semantic-interposition -fPIC -DPIC -fvisibility=hidden -I../../../liblwgeom -I../../liblwgeom -I/usr/pkg/include -I/usr/pkg/include -I/usr/pkg/include -I/usr/pkg/include/libxml2 -I/usr/pkg/include  -I/usr/pkg/include -I/usr/pkg/include/json-c -DNDEBUG -I/usr/pkg/include -I../../../libpgcommon -I/usr/pkg/include -I../../../raster/rt_pg/../rt_core -I. -I./.. -I../.. -I. -I./ -I/usr/pkg/include/postgresql/server -I/usr/pkg/include/postgresql/internal -I/usr/include -I/usr/pkg/include/libxml2 -I/usr/include/readline -I/usr/pkg/include  -I/usr/pkg/include/libxml2 -I/usr/pkg/include -I/usr/pkg/include    -c -o rtpg_internal.o ../../../raster/rt_pg/rtpg_internal.c
                 from ../../../raster/rt_pg/rtpg_internal.c:29:
../../../raster/rt_pg/rtpg_internal.c: In function ‘rtpg_strtoupper’:
../../../raster/rt_pg/rtpg_internal.c:103:37: warning: array subscript has type ‘char’ [-Wchar-subscripts]
  103 |                 str[j] = toupper(str[j]);
../../../raster/rt_pg/rtpg_internal.c: In function ‘rtpg_trim’:
../../../raster/rt_pg/rtpg_internal.c:237:24: warning: array subscript has type ‘char’ [-Wchar-subscripts]
  237 |         while (isspace(*input) && *input != '\0')
../../../raster/rt_pg/rtpg_internal.c:244:32: warning: array subscript has type ‘char’ [-Wchar-subscripts]
  244 |                 while (isspace(*--ptr))
gmake[3]: Entering directory '/n0/gdt/SOFTWARE/GEO/POSTGIS/postgis/BUILD/raster/loader'
gcc  -std=gnu11 -g -O2 -fno-math-errno -fno-signed-zeros -Wall -O2  -fPIC -DPIC -I../../../raster/loader/../rt_core -I./.. -I. -I../.. -I../../liblwgeom -I../../../liblwgeom -I/usr/pkg/include -I/usr/pkg/include -I/usr/pkg/include   -c ../../../raster/loader/raster2pgsql.c
                 from /usr/pkg/include/cpl_port.h:107,
                 from /usr/pkg/include/gdal.h:29,
                 from ../../../raster/loader/../rt_core/librtcore.h:124,
                 from ../../../raster/loader/raster2pgsql.h:42,
                 from ../../../raster/loader/raster2pgsql.c:28:
../../../raster/loader/raster2pgsql.c: In function ‘strtolower’:
../../../raster/loader/raster2pgsql.c:241:37: warning: array subscript has type ‘char’ [-Wchar-subscripts]
  241 |                 str[j] = tolower(str[j]);
../../../raster/loader/raster2pgsql.c: In function ‘trim’:
../../../raster/loader/raster2pgsql.c:325:24: warning: array subscript has type ‘char’ [-Wchar-subscripts]
  325 |         while (isspace(*input))
../../../raster/loader/raster2pgsql.c:330:24: warning: array subscript has type ‘char’ [-Wchar-subscripts]
  330 |         while (isspace(*--ptr))
gcc  -I../../liblwgeom -I../liblwgeom  -I/usr/pkg/include -I/usr/pkg/include -I/usr/pkg/include -I/usr/pkg/include/libxml2 -I/usr/pkg/include  -I/usr/pkg/include -I/usr/pkg/include/json-c -DNDEBUG  -std=gnu11 -g -O2 -fno-math-errno -fno-signed-zeros -Wall -O2  -fPIC -DPIC -I/usr/pkg/include   -c ../../loader/shp2pgsql-core.c
                 from ../../loader/shp2pgsql-core.h:19,
                 from ../../loader/shp2pgsql-core.c:22:
../../loader/shp2pgsql-core.c: In function ‘strtolower’:
../../loader/shp2pgsql-core.c:891:33: warning: array subscript has type ‘char’ [-Wchar-subscripts]
  891 |                 s[j] = tolower(s[j]);
gcc  -I../../liblwgeom -I../liblwgeom  -I/usr/pkg/include -I/usr/pkg/include -I/usr/pkg/include -I/usr/pkg/include/libxml2 -I/usr/pkg/include  -I/usr/pkg/include -I/usr/pkg/include/json-c -DNDEBUG  -std=gnu11 -g -O2 -fno-math-errno -fno-signed-zeros -Wall -O2  -fPIC -DPIC -I/usr/pkg/include   -I/usr/pkg/include -c ../../loader/pgsql2shp-core.c
                 from ../../loader/pgsql2shp-core.h:17,
                 from ../../loader/pgsql2shp-core.c:27:
../../loader/pgsql2shp-core.c: In function ‘goodDBFValue’:
../../loader/pgsql2shp-core.c:753:36: warning: array subscript has type ‘char’ [-Wchar-subscripts]
  753 |                 buf[0] = toupper(in[0]);
../../loader/pgsql2shp-core.c: In function ‘ShpDumperOpenTable’:
../../loader/pgsql2shp-core.c:1717:76: warning: array subscript has type ‘char’ [-Wchar-subscripts]
 1717 |                                 dbffieldname[nameit] = toupper(dbffieldname[nameit]);
