PostGIS 3.7.0rc3 release
Regina Obe lr at pcorp.us
Thu Oct 22 00:40:41 PDT 2026
> "Regina Obe" <lr at pcorp.us> writes:
> > The PostGIS Team is pleased to release PostGIS 3.7.0rc3! Best Served
> > with PostgreSQL 19 RC1 , GEOS 3.15.0 , This version requires
> > PostgreSQL 14 - 19rc1, GEOS 3.10 or higher, and Proj 6.1+. To take
> > advantage of all features, GEOS 3.15+ is needed. To take advantage of
> > all SFCGAL features SFCGAL 2.3.0+ is needed.
> This builds and mostly passes tests on NetBSD 11 amd64.
That's great to hear.
> The tests fail with what is obviously test environment assumptions
> problems:
>   RUNTESTFLAGS:  --topology --raster
>   RUNTESTFLAGS_INTERNAL: --after-create-db-script
> ../raster/test/regress/hooks/hook-before-create-raster.sql --before-upgrade-
> script ../raster/test/regress/hooks/hook-before-upgrade-raster.sql --before-
> upgrade-script ../topology/test/regress/hooks/hook-before-upgrade-
> topology.sql --after-create-db-script ../regress/hooks/hook-after-create-
> db.sql --before-upgrade-script ../regress/hooks/hook-before-upgrade.sql --
> after-upgrade-script ../regress/hooks/hook-after-upgrade-check-sql-object-
> resolution.sql --after-upgrade-script ../regress/hooks/hook-after-upgrade.sql
> --after-create-script   ../regress/hooks/hook-after-create.sql --before-
> uninstall-script ../regress/hooks/hook-before-uninstall.sql --after-upgrade-
> script ../topology/test/regress/hooks/hook-after-upgrade-topology.sql --after-
> upgrade-script ../raster/test/regress/hooks/hook-after-upgrade-raster.sql
>   psql: error: connection to server on socket "/tmp/.s.PGSQL.5432" failed:
> FATAL:  permission denied to set parameter "lc_messages"
>   Creating database 'postgis_reg-3.7'.
Yah this is a long standing one documented here - https://trac.osgeo.org/postgis/ticket/5212
Though I thought we had added in about POSTGIS_REGRESS_DB_OWNER but maybe not.
>   Running after-create-db-script ../raster/test/regress/hooks/hook-before-
> create-raster.sql
>   Died at ../regress/run_test.pl line 1568.
>    failed (Error encountered loading ../raster/test/regress/hooks/hook-before-
> create-raster.sql: /tmp/pgis_reg/regress_log.tmp)
>   gmake: *** [../regress/runtest.mk:24: check-regress] Error 2
> I do have my postgresql locked down more than many, but README.postgis
> doesn't say what's needed.  (I'm not a superuser.)
> There is a large amount of ctype UB.  I don't know if this is new, but I think I
> would have noticed and said something.
> Briefly, ctype functions take an int, and are defined only for values that are
> valid for unsigned char or EOF.  Everything else is UB.
> Calling them with a variable of type char, if char is signed, leads to negative
> values.  I would expect at least some systems in CI to warn somehow, but
> maybe they don't.
> libtool: compile:  gcc -I../../liblwgeom/../deps/ryu/.. -I/usr/pkg/include -
> I/usr/pkg/include -I/usr/pkg/include -I/usr/pkg/include/libxml2 -
> I/usr/pkg/include -I/usr/pkg/include -I/usr/pkg/include/json-c -DNDEBUG -I.
> -I../../liblwgeom -std=gnu11 -g -O2 -fno-math-errno -fno-signed-zeros -Wall -
> O2 -fPIC -DPIC -c ../../liblwgeom/optionlist.c  -fPIC -DPIC -o .libs/optionlist.o
> In file included from /usr/include/ctype.h:100,
>                  from ../../liblwgeom/optionlist.c:28:
> ../../liblwgeom/optionlist.c: In function 'option_list_string_to_lower':
> ../../liblwgeom/optionlist.c:36:32: warning: array subscript has type 'char' [-
> Wchar-subscripts]
>    36 |                 *key = tolower(*key);
> O2 -fPIC -DPIC -c lwin_wkt_lex.c  -fPIC -DPIC -o .libs/lwin_wkt_lex.o In file
>                  from ../../liblwgeom/lwin_wkt_lex.l:5:
> ../../liblwgeom/lwin_wkt_lex.l: In function 'wkt_yylex':
> ../../liblwgeom/lwin_wkt_lex.l:108:31: warning: array subscript has type
> 'char' [-Wchar-subscripts]
>   108 |         if (toupper(wkt_yytext[0]) == 'Z' && toupper(wkt_yytext[1]) ==
> 'M')
> ../../liblwgeom/lwin_wkt_lex.l:108:64: warning: array subscript has type
> 'M')
> ../../liblwgeom/lwin_wkt_lex.l:110:36: warning: array subscript has type
>   110 |         else if (toupper(wkt_yytext[0]) == 'Z')
> O2 -fPIC -DPIC -c ../../liblwgeom/lwin_wkt.c  -fPIC -DPIC -o .libs/lwin_wkt.o
>                  from ../../liblwgeom/lwin_wkt.c:27:
> ../../liblwgeom/lwin_wkt.c: In function 'wkt_dimensionality':
> ../../liblwgeom/lwin_wkt.c:91:50: warning: array subscript has type 'char' [-
> Wchar-subscripts]
>    91 |                 else if( ! isspace(dimensionality[i]) ) break;
> O2 -fPIC -DPIC -c ../../liblwgeom/lwalgorithm.c  -fPIC -DPIC -o
> .libs/lwalgorithm.o In file included from /usr/include/ctype.h:100,
>                  from ../../liblwgeom/lwalgorithm.c:28:
> ../../liblwgeom/lwalgorithm.c: In function 'decode_geohash_bbox':
> ../../liblwgeom/lwalgorithm.c:699:41: warning: array subscript has type 'char'
> [-Wchar-subscripts]
>   699 |                 char c = tolower(geohash[i]);
> gcc -Wall -Wmissing-prototypes -Wpointer-arith -Wdeclaration-after-
> statement -Werror=vla -Wendif-labels -Wmissing-format-attribute -Wimplicit-
> fallthrough=3 -Wcast-function-type -Wshadow=compatible-local -Wformat-
> security -fno-strict-aliasing -fwrapv -fexcess-precision=standard -Wno-format-
> truncation -Wno-stringop-truncation -O2 -I/usr/include -
> I/usr/pkg/include/libxml2 -I/usr/include/readline -I/usr/pkg/include -
> std=gnu11 -g -O2 -fno-math-errno -fno-signed-zeros -Wall -O2  -fno-semantic-
> interposition  -fPIC -DPIC -fPIC -DPIC -fvisibility=hidden -I../../liblwgeom -
> I../liblwgeom -I../../libpgcommon -I../../deps/flatgeobuf -I../../deps/wagyu -
> I../../deps/uthash/include  -I/usr/pkg/include -I/usr/pkg/include -
> I/usr/pkg/include -I/usr/pkg/include/libxml2 -I/usr/pkg/include  -
> I/usr/pkg/include -I/usr/pkg/include/json-c -DNDEBUG  -I. -I./ -
> I/usr/pkg/include/postgresql/server -I/usr/pkg/include/postgresql/internal -
> I/usr/include -I/usr/pkg/include/libxml2 -I/usr/include/readline -
> I/usr/pkg/include    -c -o lwgeom_box.o ../../postgis/lwgeom_box.c
>                  from /usr/pkg/include/postgresql/server/port.h:16,
>                  from /usr/pkg/include/postgresql/server/c.h:1360,
>                  from /usr/pkg/include/postgresql/server/postgres.h:48,
>                  from ../../postgis/lwgeom_box.c:27:
> ../../postgis/lwgeom_box.c: In function ‘BOX2D_in’:
> ../../postgis/lwgeom_box.c:68:31: warning: array subscript has type ‘char’ [-
> Wchar-subscripts]
>    68 |           str[i] = tolower(str[i]);
> I/usr/pkg/include    -c -o lwgeom_in_gml.o ../../postgis/lwgeom_in_gml.c
>                  from ../../postgis/lwgeom_in_gml.c:49:
> ../../postgis/lwgeom_in_gml.c: In function ‘parse_gml_srs’:
> ../../postgis/lwgeom_in_gml.c:557:38: warning: array subscript has type
> ‘char’ [-Wchar-subscripts]
>   557 |                         if (!isdigit(*p)) gml_lwpgerror("unknown spatial reference
> system", 5);
> ../../postgis/lwgeom_in_gml.c: In function ‘parse_gml_double’:
> ../../postgis/lwgeom_in_gml.c:604:42: warning: array subscript has type
>   604 |         if (space_before) while (isspace(*d)) d++;
> ../../postgis/lwgeom_in_gml.c:608:29: warning: array subscript has type
>   608 |                 if (isdigit(*p))
> ../../postgis/lwgeom_in_gml.c:632:34: warning: array subscript has type
>   632 |                 else if (isspace(*p))
> ../../postgis/lwgeom_in_gml.c: In function ‘parse_gml_coordinates’:
> ../../postgis/lwgeom_in_gml.c:712:24: warning: array subscript has type
>   712 |         while (isspace(*p)) p++;                /* Eat extra whitespaces if any */
> ../../postgis/lwgeom_in_gml.c:716:29: warning: array subscript has type
>   716 |                 if (isdigit(*p)) digit = true;  /* One state parser */
> ../../postgis/lwgeom_in_gml.c: In function ‘parse_gml_pos’:
> ../../postgis/lwgeom_in_gml.c:852:20: warning: array subscript has type
>   852 |     while (isspace(*pos)) pos++;        /* Eat extra whitespaces if any */
> ../../postgis/lwgeom_in_gml.c:859:21: warning: array subscript has type
>   859 |         if (isdigit(*pos)) digit = true;
> ../../postgis/lwgeom_in_gml.c: In function ‘parse_gml_poslist’:
> ../../postgis/lwgeom_in_gml.c:923:24: warning: array subscript has type
>   923 |         while (isspace(*poslist)) poslist++;    /* Eat extra whitespaces if
> any */
> ../../postgis/lwgeom_in_gml.c:926:29: warning: array subscript has type
>   926 |                 if (isdigit(*poslist)) digit = true;
> I/usr/pkg/include    -c -o lwgeom_in_kml.o ../../postgis/lwgeom_in_kml.c
>                  from ../../postgis/lwgeom_in_kml.c:40:
> ../../postgis/lwgeom_in_kml.c: In function ‘parse_kml_coordinates’:
> ../../postgis/lwgeom_in_kml.c:332:24: warning: array subscript has type
>   332 |   while (*p && isspace(*p)) ++p;
> ../../postgis/lwgeom_in_kml.c:336:18: warning: array subscript has type
>   336 |     if ( isdigit(*p) || *p == '+' || *p == '-' || *p == '.' ) {
> ../../postgis/lwgeom_in_kml.c:353:30: warning: array subscript has type
>   353 |         if ( *q && ! isspace(*q) && *q != ',' ) {
> ../../postgis/lwgeom_in_kml.c:358:30: warning: array subscript has type
>   358 |         while (*q && isspace(*q)) ++q;
> ../../postgis/lwgeom_in_kml.c:359:22: warning: array subscript has type
>   359 |         if ( isdigit(*q) || *q == '+' || *q == '-' || *q == '.' || ! *q ) {
> ../../postgis/lwgeom_in_kml.c:371:40: warning: array subscript has type
>   371 |     } else if ( *p != ',' && ! isspace(*p) ) {
> I/usr/pkg/include    -c -o lwgeom_in_marc21.o
> ../../postgis/lwgeom_in_marc21.c
>                  from ../../postgis/lwgeom_in_marc21.c:21:
> ../../postgis/lwgeom_in_marc21.c: In function ‘is_literal_valid’:
> ../../postgis/lwgeom_in_marc21.c:153:37: warning: array subscript has type
>   153 |                 if (!isdigit(literal[j])) {
> gmake[1]: Entering directory
> '/n0/gdt/SOFTWARE/GEO/POSTGIS/postgis/BUILD/topology'
> interposition  -fPIC -DPIC -fPIC -DPIC -fvisibility=hidden -I../liblwgeom -
> I../../liblwgeom -I../../libpgcommon  -I/usr/pkg/include -I/usr/pkg/include -
> I/usr/pkg/include -I/usr/pkg/include/json-c -DNDEBUG  -I. -I../../topology -
> I/usr/pkg/include    -c -o postgis_topology.o ../../topology/postgis_topology.c
>                  from ../../topology/postgis_topology.c:14:
> ../../topology/postgis_topology.c: In function ‘_lwtype_upper_name’:
> ../../topology/postgis_topology.c:145:20: warning: array subscript has type
>   145 |     *ptr = toupper(*ptr);
> gmake[3]: Entering directory
> '/n0/gdt/SOFTWARE/GEO/POSTGIS/postgis/BUILD/raster/rt_pg'
> interposition -fPIC -DPIC -fvisibility=hidden -I../../../liblwgeom -
> I../../liblwgeom -I/usr/pkg/include -I/usr/pkg/include -I/usr/pkg/include -
> I/usr/pkg/include/libxml2 -I/usr/pkg/include  -I/usr/pkg/include -
> I/usr/pkg/include/json-c -DNDEBUG -I/usr/pkg/include -I../../../libpgcommon
> -I/usr/pkg/include -I../../../raster/rt_pg/../rt_core -I. -I./.. -I../.. -I. -I./ -
> I/usr/pkg/include    -c -o rtpostgis.o ../../../raster/rt_pg/rtpostgis.c
>                  from ../../../raster/rt_pg/rtpostgis.c:132:
> ../../../raster/rt_pg/rtpostgis.c: In function ‘rt_pg_vsi_load_options’:
> ../../../raster/rt_pg/rtpostgis.c:400:48: warning: array subscript has type
>   400 |                                 *ptr = tolower(*ptr);
> I/usr/pkg/include    -c -o rtpg_internal.o ../../../raster/rt_pg/rtpg_internal.c
>                  from ../../../raster/rt_pg/rtpg_internal.c:29:
> ../../../raster/rt_pg/rtpg_internal.c: In function ‘rtpg_strtoupper’:
> ../../../raster/rt_pg/rtpg_internal.c:103:37: warning: array subscript has type
>   103 |                 str[j] = toupper(str[j]);
> ../../../raster/rt_pg/rtpg_internal.c: In function ‘rtpg_trim’:
> ../../../raster/rt_pg/rtpg_internal.c:237:24: warning: array subscript has type
>   237 |         while (isspace(*input) && *input != '\0')
> ../../../raster/rt_pg/rtpg_internal.c:244:32: warning: array subscript has type
>   244 |                 while (isspace(*--ptr))
> '/n0/gdt/SOFTWARE/GEO/POSTGIS/postgis/BUILD/raster/loader'
> gcc  -std=gnu11 -g -O2 -fno-math-errno -fno-signed-zeros -Wall -O2  -fPIC -
> DPIC -I../../../raster/loader/../rt_core -I./.. -I. -I../.. -I../../liblwgeom -
> I../../../liblwgeom -I/usr/pkg/include -I/usr/pkg/include -I/usr/pkg/include   -
> c ../../../raster/loader/raster2pgsql.c
>                  from /usr/pkg/include/cpl_port.h:107,
>                  from /usr/pkg/include/gdal.h:29,
>                  from ../../../raster/loader/../rt_core/librtcore.h:124,
>                  from ../../../raster/loader/raster2pgsql.h:42,
>                  from ../../../raster/loader/raster2pgsql.c:28:
> ../../../raster/loader/raster2pgsql.c: In function ‘strtolower’:
> ../../../raster/loader/raster2pgsql.c:241:37: warning: array subscript has type
>   241 |                 str[j] = tolower(str[j]);
> ../../../raster/loader/raster2pgsql.c: In function ‘trim’:
> ../../../raster/loader/raster2pgsql.c:325:24: warning: array subscript has type
>   325 |         while (isspace(*input))
> ../../../raster/loader/raster2pgsql.c:330:24: warning: array subscript has type
>   330 |         while (isspace(*--ptr))
> gcc  -I../../liblwgeom -I../liblwgeom  -I/usr/pkg/include -I/usr/pkg/include -
> I/usr/pkg/include -I/usr/pkg/include/json-c -DNDEBUG  -std=gnu11 -g -O2 -
> fno-math-errno -fno-signed-zeros -Wall -O2  -fPIC -DPIC -I/usr/pkg/include   -c
> ../../loader/shp2pgsql-core.c
>                  from ../../loader/shp2pgsql-core.h:19,
>                  from ../../loader/shp2pgsql-core.c:22:
> ../../loader/shp2pgsql-core.c: In function ‘strtolower’:
> ../../loader/shp2pgsql-core.c:891:33: warning: array subscript has type ‘char’
> [-Wchar-subscripts]
>   891 |                 s[j] = tolower(s[j]);
> I/usr/pkg/include -c ../../loader/pgsql2shp-core.c
>                  from ../../loader/pgsql2shp-core.h:17,
>                  from ../../loader/pgsql2shp-core.c:27:
> ../../loader/pgsql2shp-core.c: In function ‘goodDBFValue’:
> ../../loader/pgsql2shp-core.c:753:36: warning: array subscript has type ‘char’
> [-Wchar-subscripts]
>   753 |                 buf[0] = toupper(in[0]);
> ../../loader/pgsql2shp-core.c: In function ‘ShpDumperOpenTable’:
> ../../loader/pgsql2shp-core.c:1717:76: warning: array subscript has type
>  1717 |                                 dbffieldname[nameit] =
> toupper(dbffieldname[nameit]);
I'll have to take closer look at this one.  I would have expected our bots that have warning flags turned on would have flagged these.
Which version of PostgreSQL and gcc compiler are you running with?
