[OSRS-PROJ] problem with azimuth and distance
Gerald I. Evenden
gevenden at capecod.net
Tue Jun 6 07:15:21 PDT 2000
If it is a "non great circle" route, what kind of route is it?
A rhumb line (loxodrome)? If so, you can work in Mercator space
with a straight line and inverse project the intermediate points.
You question needs more qualifications.
__________________________________________________
Jerry Evenden and the Low Riders, Katie and Daisy May
gevenden at capecod.net http://www.capecod.net/~gevenden
----- Original Message -----
To: <osrs-proj at remotesensing.org>
Sent: Tuesday, June 06, 2000 3:04 AM
Subject: Re: [OSRS-PROJ] problem with azimuth and distance
> OK, now it's clear to me.
> Let's go farther:
> Is there any way to follow a non great circle route using the proj.4
> library? For example: I want to determine a point in the 80 degrees
> North parallel 100 miles away from one given in the 80 degrees parallel
> too.
OSRS PRoject PROJ Discussion List
To Subscribe: send a message to majordomo at remotesensing.org with 'subscribe osrs-proj' in the body
To Unsubscribe: send a message to majordomo at remotesensing.org with 'unsubscribe osrs-proj' in the body
To Report Problems: send a message to owner-osrs-proj at remotesensing.org
More information about the Proj
