[OSRS-PROJ] Problem with geod sources
Ildefonso Junquero
junquero at sainsel.es
Fri Jun 9 09:37:37 PDT 2000
Hi!
I'm currently using Proj4 and found an error with geod the problem
is that If I run:
geod +ellps=WGS84
and enter:
90s 0e 89s 0e
180d 0d 19892237.570 Is returned, and this is not a correct
result
90n 0e 89n 0e
0d 180d 19892237.570 Is returned, and this is not a correct
result
90n 0e 89s 0e
0d 180d 111693.865 Is returned, and this value is correct
if it was 89n instead of 89s
I'm using PROJ 4.4.1 in Windows NT SP5, Microsoft Visual C++6 SP3.
Thank you for any help in advance.
Best regards.
Ilde.
______________________________________________________________________
Ildefonso Junquero e at mail : junquero at sainsel.es
___ __o Software Engineer
____ _'\<,_ Sainsel Sistemas Navales S.A.
______ (*)/ (*) C/ Manuel Velasco Pando, N. 7
41007 Sevilla (Spain)
Go faster! Phone : +34-95-493 64 65
Use the byke! Fax : +34-95-493 64 33
OSRS PRoject PROJ Discussion List
To Subscribe: send a message to majordomo at remotesensing.org with 'subscribe osrs-proj' in the body
To Unsubscribe: send a message to majordomo at remotesensing.org with 'unsubscribe osrs-proj' in the body
To Report Problems: send a message to owner-osrs-proj at remotesensing.org
More information about the Proj
