[OSRS-PROJ] PROJ.4 "proj=latlong ellps=GRS80" functionality?
Craig Bruce csbruce at cubewerx.com
Fri Aug 3 09:26:15 PDT 2001
"Ed McNierney" <ed at topozone.com> wrote:
> That is, my input coordinate (-71, 43) is transformed to (-1.24, 0.75).
> What does this mean?  I would expect the output results to be either
> identical to my input (if the input data is presumed to be in the output
> ellipsoid or if GRS80 or WGS84 is the default) or I would expect them to
> be very slightly different (if the input ellipsoid is something else).
It looks to me like the output is the same coordinate value as the input,
except translated into radians.  Since only two decimal places seem to be
showing, you probably wouldn't see any difference between GRS80 and WGS84,
though I don't think the ellipsoid is switched in this invocation.
Dr. Craig S. Bruce        | Tel: 819-771-8303 x205 |             CubeWerx Inc.
Senior Software Developer |   Home: 613-565-1344   |      Hull, Québec, Canada
csbruce at cubewerx.com      | http://www.csbruce.com |  http://www.cubewerx.com/
      "This message contains a Unix e-mail virus.  It works based on the
     honour system.  Please send this message to everyone in your address
          book with a sensitive personal document as an attachment."
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
