[OSRS-PROJ] PROJ.4 "proj=latlong ellps=GRS80" functionality?
Ed McNierney ed at topozone.com
Fri Aug 3 09:46:52 PDT 2001
Craig -
Thanks!  Somehow that didn't occur to me as I stared at those numbers.
After looking at values with more decimal places, it appears that the
input coordinates are presumed to be relative to the ellipsoid specified
in the output (i.e. no datum shift involved).  That makes sense and is
what I expect.
Now I've got a different problem to solve, but that's a MapServer
discussion, not PROJ.4.  Thanks again.
	- Ed
Ed McNierney
Chief Mapmaker
TopoZone.com
ed at topozone.com
(978) 251-4242
-----Original Message-----
Sent: Friday, August 03, 2001 12:26 PM
To: osrs-proj at remotesensing.org
Subject: Re: [OSRS-PROJ] PROJ.4 "proj=latlong ellps=GRS80"
functionality?
"Ed McNierney" <ed at topozone.com> wrote:
> That is, my input coordinate (-71, 43) is transformed to (-1.24,
0.75).
> What does this mean?  I would expect the output results to be either
> identical to my input (if the input data is presumed to be in the
output
> ellipsoid or if GRS80 or WGS84 is the default) or I would expect them
to
> be very slightly different (if the input ellipsoid is something else).
It looks to me like the output is the same coordinate value as the
input,
except translated into radians.  Since only two decimal places seem to
be
showing, you probably wouldn't see any difference between GRS80 and
WGS84,
though I don't think the ellipsoid is switched in this invocation.
Dr. Craig S. Bruce        | Tel: 819-771-8303 x205 |
CubeWerx Inc.
Senior Software Developer |   Home: 613-565-1344   |      Hull, Québec,
Canada
csbruce at cubewerx.com      | http://www.csbruce.com |
http://www.cubewerx.com/
      "This message contains a Unix e-mail virus.  It works based on the
     honour system.  Please send this message to everyone in your
address
          book with a sensitive personal document as an attachment."
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
