[OSRS-PROJ] Proj.4 in MS Visual C++ MFC
Ed McNierney ed at topozone.com
Fri Aug 24 10:57:01 PDT 2001
Jere -
PROJ 4.4.3 (the version I'm using) includes a Visual C++ makefile in the
src directory - makefile.vc.  You can build under MS Visual C++ by just
going to that directory and running NMAKE:
cd src
nmake /f makefile.vc
It worked flawlessly for me the first time with no modification or
tweaking at all.
    - Ed
Ed McNierney
Chief Mapmaker
TopoZone.com
ed at topozone.com
(978) 251-4242
-----Original Message-----
From: Hawkswan at aol.com [mailto:Hawkswan at aol.com]
Sent: Friday, August 24, 2001 1:39 PM
To: osrs-proj at remotesensing.org
Subject: [OSRS-PROJ] Proj.4 in MS Visual C++ MFC
Does anyone have or know of someone's experience in using or having
proj.4
source files for integrating proj.4 in MS Visual C++ MFC environment.
I've
been trying to employ proj.4 in my applications but am having
considerable
trouble getting the proj.4 library to compile and link without multiple
errors and other incompatibilities with the MS.  I have successfully
incorporated proj.4 into PC applications using MKS NutCracker (which
lays a
unix environment over MS Windows), but would like to proceed to a pure
MS
implementation.
Jere Swanson
hawkswan at aol.com
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
