[OSRS-PROJ] Proj.4 in MS Visual C++ MFC
Willem Fourie
willem at businessware.cjb.net
Fri Aug 24 11:06:40 PDT 2001
Jere
Am currently using Proj.4.3.3 in an MFC DLL as well as an MFC OCX. It is generated as a static library and then linked into the DLL or OCX. It compiles with some warnings but zero errors and links with zero errors
Contact me and perhaps I can send you my entire PROJ4 .dsw, .dsp and source files.
Willem Fourie
----- Original Message -----
To: osrs-proj at remotesensing.org
Sent: Friday, August 24, 2001 7:39 PM
Subject: [OSRS-PROJ] Proj.4 in MS Visual C++ MFC
Does anyone have or know of someone's experience in using or having proj.4
source files for integrating proj.4 in MS Visual C++ MFC environment. I've
been trying to employ proj.4 in my applications but am having considerable
trouble getting the proj.4 library to compile and link without multiple
errors and other incompatibilities with the MS. I have successfully
incorporated proj.4 into PC applications using MKS NutCracker (which lays a
unix environment over MS Windows), but would like to proceed to a pure MS
implementation.
Jere Swanson
hawkswan at aol.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20010824/c615b616/attachment.html>
More information about the Proj
