Rép. : [OSRS-PROJ] Proj.4 in MS Visual C++ MFC
Frank Warmerdam
warmerdam at pobox.com
Tue Aug 28 06:30:42 PDT 2001
Emmanuel Verlynde wrote:
> Personnaly i have integrated proj4 into an windows application without any problems. I use c++builder to compile and link proj4 into a ".lib" incorporated into a .exe and a lot of warning messages appears but are not really important. Also the definition HUGE_VAL is not useable like the unix version... if anyone can find a sloution for this problem... send me the answer. thanks.
Emmanuel,
I don't think I run into problems with HUGE_VAL on windows. What problem are
you running into? I guess it isn't defined in the C++Builder include files?
I imagine you can just #define it to a large/unlikely value in proj_api.h if
it isn't already defined. The important thing is that the value won't
occur in normal use, and that the same value is used in the library and the
calling application.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
More information about the Proj
