[OSRS-PROJ] PROJ4 and Krovak projection (Czech Republic)?
Markus Neteler neteler at itc.it
Wed Apr 3 12:39:43 PST 2002
On Wed, Apr 03, 2002 at 07:35:59PM +0200, Thomas Flemming wrote:
> Hi Markus,
> last year I asked the same question, because we need this projection in
> our GPS-Software.
> I've got no answer, so I figured it out myself. It works, but I'm not
> sure, if it is really correct integrated in proj.4.
> For me, it is still very hard, to understand, how proj works. Anyway,
> this is not my job.
Hi Thomas,
also we have a hard time currently as we want to integrate the ISIN
projection for MODIS/TERRA stellite data. That's far from trivial.
> If you like, I send you the c-sourcefile for the Krovak-Projection for
> Proj.4.
Oh great - I'll appreciate that. You efforts will also help the GRASS
GIS software where our Czech users may need it.
Thanks in advance,
 Markus
> Markus Neteler schrieb:
> > Hi,
> > I am curious if it is possible to define the Krovak projection
> > in PROJ4 (finally I want to do that in GRASS).
> > The definition is:
> >  http://www.ihsenergy.com/epsg/guid7.html#1.4.3
> > Parameters:
> >        Ellipsoid Bessel 1841 a = 6377397.155m 1/f = 299.15281
> >          then e = 0.081696831 e2 = 0.006674372
> >        Latitude of projection centre (j_c) 49° 30'00" N = 0.604756586 rad
> >        Longitude of Origin 42° 30'00" East of Ferro
> >        Longitude of Ferro is 17° 40'00" West of Greenwich
> >        Longitude of Origin (l_c) 24° 50'00" East of Greenwich=0.433423431 rad
> >        Latitude of pseudo standard parallel (j_1) 78° 30'00" N
> >        Azimuth of centre line (a_c) 30° 17' 17.303"
> >        Scale factor on pseudo Standard Parallel (ko) 0.99990
> >        Easting at projection centre (Ec) 0.00 m
> >        Northing at projection centre (Nc) 0.00 m
> > Projection constants:
> >          B = 1.000597498
> >          A = 6380703.61
> >          g 0 = 0.863239103
> >          t0 = 1.003419164
> >          n = 0.979924705
> >          r0 = 1298039.005
> > It might be also called "S-JTSK Ferro Krovak".
> > As being only experienced a bit with Transverse Mercator, I am a bit
> > lost with this Krovak projection.
> > Thanks in advance for any hint (or a proj command line...)
> >  Markus Neteler
> > PS: There is also another description with all history:
> >     http://www.asprs.org/asprs/resources/grids/index.html
> >     -> The Czech Republic
> > PROJ.4 Discussion List
> > See http://www.remotesensing.org/proj for subscription, unsubscription
> > and other information.
> **   Dipl.-Ing. Thomas Flemming
> **      Software Development
> **  thomas.flemming at touratech.de
> **          tf at ttqv.com
> **      http://www.ttqv.com
> ** ... und immer dem Pfeil nach!
Markus Neteler
ITC-irst, Istituto per la Ricerca Scientifica e Tecnologica
     Project on Predictive Models for the Environment
Via Sommarive, 18        -      38050 Povo (Trento), Italia
tel +39 0461 314 -520 (fax -591)          http://mpa.itc.it
