[OSRS-PROJ] PROJ4 and Krovak projection (Czech Republic)?
Thomas Flemming tf at ttqv.com
Thu Apr 4 00:32:40 PST 2002
here it is.
The code was translated from a fortran77 source provided from the
czechic Research Institute of Geodesy, Topography and Cartography to c.
The main problem for me was how to extend the proj library with a new
projection.
I don't think, that I solved this perfectly, but it works...
Hope, this will help.
Tom
 * pj_qv_krovak.c
 * Krovak Projection for Proj.4
 * last change 16.1.2002
 * Copyright (c) 2001, Thomas Flemming, tf at ttqv.com
 * Permission is hereby granted, free of charge, to any person obtaining
a
 * copy of this software and associated documentation files (the
"Software"),
 * to deal in the Software without restriction, including without
limitation
 * the rights to use, copy, modify, merge, publish, distribute,
sublicense,
 * and/or sell copies of the Software, and to permit persons to whom the
 * Software is furnished to do so, subject to the following conditions:
 * The above copyright notice and this permission notice shall be
included
 * in all copies or substantial portions of the Software.
 * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND,
EXPRESS
 * OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF
MERCHANTABILITY,
 * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT
SHALL
 * THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR
OTHER
 * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE,
ARISING
 * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
 * DEALINGS IN THE SOFTWARE.
#ifndef lint
static const char SCCSID[]="@(#)pj_qv_krovak.c	4.1	94/02/15	GIE	REL";
#endif
#define PROJ_PARMS__ \
	double	C_x;
#define PJ_LIB__
#include	<projects.h>
// insert this line to pj_list.h
PROJ_HEAD(krovak, "Krovak") "\n\tPCyl., Sph.";
FORWARD(s_forward); /* spheroid */
//xy von lat/lon ausrechnen
				char errmess[255];
				char tmp[16];
// Constants, identisch wie in der Umkehrfunktion
	double s45, s90, fi0, e2, e, alfa, uq, u0, g, k, k1, n0, ro0, ad, a,
s0, n;
	double gfi, u, lon17, lon42, lamdd, deltav, s, d, eps, ro;
	s45 = 0.785398163397448;    // 45°
	s90 = 2 * s45;
	fi0 = 0.863937979737193;    //Latitude of projection centre 49° 30//
   /* Ellipsoid wird als Übergabeparameter in for.c und inv.c
versrbeitet
      daher muß a hier auf 1 gesetzt werden
      Ellipsoid Bessel 1841 a = 6377397.155m 1/f = 299.15281,
e2=0.006674372230614;
	a = 1;            //6377397.155;
	e2 = P->es;       //0.006674372230614;
	e = sqrt(e2);
	alfa = sqrt(1. + (e2 * pow(cos(fi0), 4)) / (1. - e2));
	uq = 1.04216856380474;      //DU(2, 59, 42, 42.69689)
	u0 = asin(sin(fi0) / alfa);
	g = pow(   (1. + e * sin(fi0)) / (1. - e * sin(fi0)) ,
              alfa * e / 2.  );
	k =         tan( u0 / 2. + s45) /
         pow  (tan(fi0 / 2. + s45) , alfa) *
               g;
	k1 = 0.9999;
	n0 = a * sqrt(1. - e2) / (1. - e2 * pow(sin(fi0), 2));
	s0 = 1.37008346281555;       //Latitude of pseudo standard parallel
78° 30'00" N
	n = sin(s0);
	ro0 = k1 * n0 / tan(s0);
	ad = s90 - uq;
// Transformation
	gfi =pow ( ((1. + e * sin(lp.phi)) /
               (1. - e * sin(lp.phi))) , (alfa * e / 2.));
   u= 2. * (atan(k * pow( tan(lp.phi / 2. + s45), alfa) / gfi)-s45);
	lon17 = 0.308341501185665;                                // Longitude
of Ferro is 17° 40'00" West of Greenwich
	lon42 = 0.74176493209759;                                 // Longitude
of Origin 42° 30'00" East of Ferro
	lamdd = lp.lam + lon17;
	deltav = alfa * (lon42 - lamdd);
	s = asin(cos(ad) * sin(u) + sin(ad) * cos(u) * cos(deltav));
	d = asin(cos(u) * sin(deltav) / cos(s));
	eps = n * d;
	ro = ro0 * pow(tan(s0 / 2. + s45) , n) /
              pow(tan(s / 2. + s45) , n)   ;
   // x und y vertauscht!
	xy.y = ro * cos(eps);
	xy.x = ro * sin(eps);
 /*           //debug
				strcpy(errmess,"a: ");
				strcpy(tmp,"        ");
				ltoa((long)(a*1000000000),tmp,10);
				strcat(errmess,tmp);
				strcat(errmess,"e2: ");
				strcpy(tmp,"        ");
				ltoa((long)(e2*1000000000),tmp,10);
            MessageBox(NULL, errmess, NULL, 0);
	return (xy);
INVERSE(s_inverse); /* spheroid */
	// lat/lon von xy ausrechnen
s0, n;
	double u, l24, lamdd, deltav, s, d, eps, ro, fi1, xy0;
   int ok;
	s90 = 2 * s45;
versrbeitet
	e = sqrt(e2);
              alfa * e / 2.  );
         pow  (tan(fi0 / 2. + s45) , alfa) * g;
	k1 = 0.9999;
78° 30'00" N
	n = sin(s0);
	ad = s90 - uq;
// Transformation
   //vertauschen
   xy0=xy.x;
   xy.x=xy.y;
   xy.y=xy0;
	ro = sqrt(xy.x * xy.x + xy.y * xy.y);
	eps = atan2(xy.y, xy.x);
	d = eps / sin(s0);
	s = 2. * (atan(  pow(ro0 / ro, 1. / n) * tan(s0 / 2. + s45)) - s45);
   u = asin(cos(ad) * sin(s) - sin(ad) * cos(s) * cos(d));
   deltav = asin(cos(s) * sin(d) / cos(u));
   l24 = 0.433423430911925;   //DU(2, 24, 50, 0.)
   lp.lam = l24 - deltav / alfa;
// ITERATION FOR lp.phi
   fi1 = u;
   ok = 0;
   do
   	lp.phi = 2. * ( atan( pow( k, -1. / alfa)  *
                            pow( tan(u / 2. + s45) , 1. / alfa)  *
                            pow( (1. + e * sin(fi1)) / (1. - e *
sin(fi1)) , e / 2.)
                           )  - s45);
      if (fabs(fi1 - lp.phi) < 0.000000000000001) ok=1;
      fi1 = lp.phi;
   while (ok==0);
	return (lp);
FREEUP; if (P) pj_dalloc(P); }
ENTRY0(krovak)
	double ts;
	// irgendwelche Parameter auslesen,
	// hier Latitude Truescale
	ts = pj_param(P->params, "rlat_ts").f;
	P->C_x = ts;
	// immer gleich
	//P->es = 0.;
   P->inv = s_inverse; P->fwd = s_forward;
ENDENTRY(P)
Markus Neteler schrieb:
> On Wed, Apr 03, 2002 at 07:35:59PM +0200, Thomas Flemming wrote:
> > Hi Markus,
> > last year I asked the same question, because we need this projection in
> > our GPS-Software.
> > I've got no answer, so I figured it out myself. It works, but I'm not
> > sure, if it is really correct integrated in proj.4.
> > For me, it is still very hard, to understand, how proj works. Anyway,
> > this is not my job.
> Hi Thomas,
> also we have a hard time currently as we want to integrate the ISIN
> projection for MODIS/TERRA stellite data. That's far from trivial.
> > If you like, I send you the c-sourcefile for the Krovak-Projection for
> > Proj.4.
> Oh great - I'll appreciate that. You efforts will also help the GRASS
> GIS software where our Czech users may need it.
> Thanks in advance,
>  Markus
> > > Hi,
> > > I am curious if it is possible to define the Krovak projection
> > > in PROJ4 (finally I want to do that in GRASS).
> > > The definition is:
> > >  http://www.ihsenergy.com/epsg/guid7.html#1.4.3
> > > Parameters:
> > >          then e = 0.081696831 e2 = 0.006674372
> > >        Latitude of projection centre (j_c) 49° 30'00" N = 0.604756586 rad
> > >        Longitude of Origin 42° 30'00" East of Ferro
> > >        Longitude of Ferro is 17° 40'00" West of Greenwich
> > >        Longitude of Origin (l_c) 24° 50'00" East of Greenwich=0.433423431 rad
> > >        Latitude of pseudo standard parallel (j_1) 78° 30'00" N
> > >        Azimuth of centre line (a_c) 30° 17' 17.303"
> > >        Scale factor on pseudo Standard Parallel (ko) 0.99990
> > >        Easting at projection centre (Ec) 0.00 m
> > >        Northing at projection centre (Nc) 0.00 m
> > > Projection constants:
> > >          B = 1.000597498
> > >          A = 6380703.61
> > >          g 0 = 0.863239103
> > >          t0 = 1.003419164
> > >          n = 0.979924705
> > >          r0 = 1298039.005
> > > It might be also called "S-JTSK Ferro Krovak".
> > > As being only experienced a bit with Transverse Mercator, I am a bit
> > > lost with this Krovak projection.
> > > Thanks in advance for any hint (or a proj command line...)
> > >  Markus Neteler
> > > PS: There is also another description with all history:
> > >     http://www.asprs.org/asprs/resources/grids/index.html
> > >     -> The Czech Republic
> > > PROJ.4 Discussion List
> > > See http://www.remotesensing.org/proj for subscription, unsubscription
> > > and other information.
> > **   Dipl.-Ing. Thomas Flemming
> > **      Software Development
> > **  thomas.flemming at touratech.de
> > **          tf at ttqv.com
> > **      http://www.ttqv.com
> > ** ... und immer dem Pfeil nach!
> Markus Neteler
> ITC-irst, Istituto per la Ricerca Scientifica e Tecnologica
>      Project on Predictive Models for the Environment
> Via Sommarive, 18        -      38050 Povo (Trento), Italia
> tel +39 0461 314 -520 (fax -591)          http://mpa.itc.it
**          tf at ttqv.com
