[OSRS-PROJ] nad2nad command syntax
Jack Bowling
jbinpg at shaw.ca
Mon Apr 8 22:44:51 PDT 2002
** Reply to message from Frank Warmerdam <warmerdam at pobox.com> on Mon, 08 Apr 2002 11:38:03 -0400
> http://www.remotesensing.org/proj
> Jack Bowling wrote:
> >>% nad2nad -i,83,utm=10,-o,27,utm=10 -
> Jack,
> I fixed a couple other problems in your syntax but forgot to include it:
> % nad2nad -i,83,utm=10 -o,27,utm=10 -
Actually, I seem to be getting a bit closer with nad2nad. I removed the older rpm and compiled the latest source. Here is the incantation that at least lets me talk to the code:
# nad2nad -i 83,utm=10 -o 27,utm=10 -
Rel. 4.4.5, 9 January 2002
<nad2nad>:
conversion region (-r) not specified
program abnormally terminated
So I try:
# nad2nad -i 83,utm=10 -o 27,utm=10 -r ntv1_can -
<nad2nad>:
datum file: ntv1_can, failed: no system list, errno: 2
A check of my /usr/local/src/proj4*/nad directory reveals the following files:
# ls
alaska.lla hawaii.lla nad27 pj_out83.dist README.NADUS test83
conus.lla Makefile nad83 proj_def.dat stgeorge.lla TN.lla
epsg Makefile.am nad.lst proj-nad27-1.1.tar.gz stlrnc.lla WI.lla
FL.lla Makefile.in ntv1_can.dat prvi.lla stpaul.lla WO.lla
GL27 MD.lla pj_out27.dist README test27 world
Was an ntv1_can.lla file supposed to have been created during the compile?
jb
Jack Bowling
mailto: jbinpg at shaw.ca
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
More information about the Proj
