[OSRS-PROJ] nad2nad command syntax
Wed Apr 10 06:18:07 PDT 2002
Jack Bowling wrote:
 > So I try:
 > # nad2nad -i 83,utm=10 -o 27,utm=10 -r ntv1_can -
 > Rel. 4.4.5, 9 January 2002
 > <nad2nad>:
 > datum file: ntv1_can, failed: no system list, errno: 2
 > program abnormally terminated
 > A check of my /usr/local/src/proj4*/nad directory reveals the following files:
 > # ls
 > alaska.lla  hawaii.lla   nad27          pj_out83.dist          README.NADUS  test83
 > conus.lla   Makefile     nad83          proj_def.dat           stgeorge.lla  TN.lla
 > epsg        Makefile.am  nad.lst        proj-nad27-1.1.tar.gz  stlrnc.lla    WI.lla
 > FL.lla      Makefile.in  ntv1_can.dat   prvi.lla               stpaul.lla    WO.lla
 > GL27        MD.lla       pj_out27.dist  README                 test27        world
 > Was an ntv1_can.lla file supposed to have been created during the compile?
Jack,
The ntv1_can.dat file is in a different format than the US files, and doesn't
work with nad2nad but does work with cs2cs. At least I think that is the issue.
Best regards,
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
