[OSRS-PROJ] libproj.so
Kathy Bieltz
kbieltz at hal-pc.org
Thu Apr 11 06:44:30 PDT 2002
Cyril,
Is libproj.so installed in a directory that
you have already put in /etc/ld.so.conf ?
If not, then add it to /etc/ld.so.conf and
then run 'ldconfig'. This sets the search
path for you system to look for shared
libraries.
Kathy Bieltz
Cyril Bonnard wrote:
> Hi, I use the the PROJ.4 library and there no problem with windows
> but when i try with linux the program is unable to locate and load
> PROJ.4(libproj.so).
> I think either libproj.so isn't in the right folder or GNMAKEFILE is not OK.
> Since i am a rookie could help me to do the right thing!
> thanks in advance
> Cyril
> PROJ.4 Discussion List
> See http://www.remotesensing.org/proj for subscription, unsubscription
> and other information.
More information about the Proj
