[OSRS-PROJ] libproj.so
Cyril Bonnard cyril.bonnard at esisar.inpg.fr
Thu Apr 11 07:18:08 PDT 2002
Thanks for your help,
in fact i  don't use proj4 with command-line, i use it in a program which
uses GDALInfoReportCorner() of gdalinfo. So libproj.so and all packages are
not /usr/local/lib or in any default path, I compile everything in my
personal folder /home/esisar/gdal-1.1.6/proj4...
I'am going to follow your advice and i will tell you if you were right (I
hope so!)
Cyril Bonnard
-----Message d'origine-----
De : owner-osrs-proj at remotesensing.org
[mailto:owner-osrs-proj at remotesensing.org]De la part de Kathy Bieltz
Envoye : jeudi 11 avril 2002 15:45
A : osrs-proj at remotesensing.org
Objet : Re: [OSRS-PROJ] libproj.so
Cyril,
Is libproj.so installed in a directory that
you have already put in /etc/ld.so.conf ?
If not, then add it to /etc/ld.so.conf and
then run 'ldconfig'.  This sets the search
path for you system to look for shared
libraries.
Kathy Bieltz
Cyril Bonnard wrote:
> Hi, I use the the PROJ.4 library and there no problem with windows
>  but when i try with linux  the program is unable to locate and load
> PROJ.4(libproj.so).
> I think either libproj.so isn't in the right folder or GNMAKEFILE is not
OK.
> Since i am a rookie could help me to do the right thing!
> thanks in advance
> Cyril
> PROJ.4 Discussion List
> See http://www.remotesensing.org/proj for subscription, unsubscription
> and other information.
