[OSRS-PROJ] libproj.so
Cyril Bonnard cyril.bonnard at esisar.inpg.fr
Thu Apr 11 07:54:57 PDT 2002
I've just done what you said but it failed again  ;( :
here is the result (see the errors)
[root at PC324 apps]# ./gdalinfo -mm ./donnees/9037catd.ddf
Driver: SDTS/SDTS Raster
Size is 391, 463
Coordinate System is:
PROJCS["UTM Zone 11, Northern Hemisphere",
    GEOGCS["NAD27",
        DATUM["North_American_Datum_1927",
            SPHEROID["Clarke 1866",6378206.4,294.978698213898,
                AUTHORITY["EPSG",7008]],
            TOWGS84[-3,142,183,0,0,0,0],
            AUTHORITY["EPSG",6267]],
        PRIMEM["Greenwich",0,
            AUTHORITY["EPSG",8901]],
        UNIT["degree",0.0174532925199433,
            AUTHORITY["EPSG",9108]],
        AXIS["Lat","NORTH"],
        AXIS["Long","EAST"],
        AUTHORITY["EPSG",4267]],
    PROJECTION["Transverse_Mercator"],
    PARAMETER["latitude_of_origin",0],
PARAMETER["central_meridian",-117],
PARAMETER["scale_factor",0.9996],
PARAMETER["false_easting",500000],
PARAMETER["false_northing",0]]
Origin = (523395.000000,3637305.000000)
Pixel Size = (30.000000,-30.000000)
Corner Coordinates:
ERROR 1: ./gdalinfo: undefined symbol: pj_transform
ERROR 1: ./gdalinfo: undefined symbol: pj_get_errno_ref
ERROR 1: Attempt to load libproj.so, but couldn't find pj_transform.
Please upgrade to PROJ 4.1.2 or later.
ERROR 6: Unable to load PROJ.4 library (libproj.so), creation of
OGRCoordinateTransformation failed.
Upper Left  (  523395.000, 3637305.000)
ERROR 6: Failed to initialize PROJ.4 with `+proj=longlat +ellps=clrk66
+datum=NAD27 '.
Lower Left  (  523395.000, 3623415.000)
+datum=NAD27 '.
Upper Right (  535125.000, 3637305.000)
+datum=NAD27 '.
Lower Right (  535125.000, 3623415.000)
+datum=NAD27 '.
Center      (  529260.000, 3630360.000)
Band 1 Block=391x1 Type=Int16, ColorInterp=Undefined
  Min=-32768.000/0, Max=32767.000/0, Computed Min/Max=414.000,1265.000
  NoData Value=-32766
  Unit Type: m
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
