[OSRS-PROJ] Projection Parameters Meta Information
Michael Lacher
michael.lacher at geospace.co.at
Fri Apr 19 01:41:12 PDT 2002
Hi!
I am employing PROJ in a project, and one task is to convert map
coordinates into a user definable coordinate system for display of
cursor position. So far the selectable projections was fixed and
relatively small, but now the user wants more projections to be added to
this list.
I think the best way to achieve this in an extendible fashion would be
to build a set of metadescriptions for PROJ projections and parameters,
which would ideally be stored in a file. The the system reads this file
(which can then be updated for newer versions of proj) and automatically
constructs a user interface which lets the user enter the appropriate
parameters.
What would be needed would be something like:
For projection type:
* human readable name
* name used by PROJ
* parameters which can be used with this projection
For ellipse:
* name used by PROJ
For Parameters
* name used by PROJ
* internal unique ID which is used by projection type to specify the
links between projection and parameters
My question is: Does something like this exist already (preferrable as a
free library) ?
If yes: where can I find informatino about it ?
If no: would anyone (except me) be interested in such a thing ?
Mucki
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
More information about the Proj
