[OSRS-PROJ] Projection Parameters Meta Information
Frank Warmerdam
warmerdam at pobox.com
Fri Apr 19 06:18:19 PDT 2002
Michael Lacher wrote:
> What would be needed would be something like:
> For projection type:
> * human readable name
> * name used by PROJ
> * parameters which can be used with this projection
> For ellipse:
> * name used by PROJ
> For Parameters
> * name used by PROJ
> * internal unique ID which is used by projection type to specify the
> links between projection and parameters
> My question is: Does something like this exist already (preferrable as a
> free library) ?
> If yes: where can I find informatino about it ?
> If no: would anyone (except me) be interested in such a thing ?
Michael,
Part of what you want is readily available. The projection and ellipse
list with ids and descriptions can be fetched from the commandline using
the "proj -le" or "proj -lp" commands. These can be accessed programatically
... see proj.c to see how it does it.
However, what isn't available is:
o A list of parameters that apply to each projection.
o The long names of the parameters
In fact, this would be very nice to have but it doesn't exist anywhere in
an organized way. If you would like to develop an internal data structure
holding this information I would be pleased to cooperate with you to
incorporate it into the core PROJ.4 system.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
More information about the Proj
