[OSRS-PROJ] FOUND THE ANSWER to: problems with ' and " in coordinates? (fwd)
Agustin Lobo
alobo at ija.csic.es
Fri Apr 19 09:32:35 PDT 2002
Sorry, I've realized that the correct format
is
+lat_1="37d10'41.058"
and not:
+lat_1=37d10'41.058"
I thought that as ' stands for min, " meant seconds.
Agus
Dr. Agustin Lobo
Instituto de Ciencias de la Tierra (CSIC)
Lluis Sole Sabaris s/n
08028 Barcelona SPAIN
tel 34 93409 5410
fax 34 93411 0012
---------- Forwarded message ----------
Date: Fri, 19 Apr 2002 18:25:35 +0200 (MET DST)
To: osrs-proj at remotesensing.org
Subject: problems with ' and " in coordinates?
Hi!
I'm using PROJ to transform from lcc to lon,lat
and I'm confused by the following:
If I use:
proj -I +proj=lcc +a=6378388.0000000000 +es=0.0067226700 +lat_0=40.0
+lat_1=37.1780716667 +lat_2=42.8219283333 +lon_0=-3.687500 +x_0=600000.0
+y_0=600000.0 +unfact=1.0000000000 <<EOF
> 600000 600000
> EOF
I get the correct result:
3d41'15"W 40dN
But if I use ' and " for the coordinates (i.e.,+lat_1=37d10'41.058"
instead
of +lat_1=37.1780716667 ), I get a wrong result:
proj -I +ellps=intl +proj=lcc +x_0=600000 +y_0=600000
+lat_1=37d10'41.058" +lat_2=42d49'18.9420" +lon_0=-3d41'15" +lat_0=40d
<<EOF
> 600000 600000
> EOF
0dE 40dN
As I understand from the man page, both notations
are correct, where is the problem?
Thanks
Agus
Dr. Agustin Lobo
tel 34 93409 5410
fax 34 93411 0012
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
More information about the Proj
