[OSRS-PROJ] problems with ' and " in coordinates?
Frédéric Trastour dev at geoimage.fr
Fri Apr 19 09:52:07 PDT 2002
Hello,
the shell interprets ' and " as special characters.
You must pust a \ before each of them.
For example, the following should work better :
proj -I +ellps=intl +proj=lcc +x_0=600000  +y_0=600000
+lat_1=37d10\'41.058\"  +lat_2=42d49\'18.9420\"  +lon_0=-3d41\'15\"
+lat_0=40d
----- Original Message -----
To: <osrs-proj at remotesensing.org>
Sent: Friday, April 19, 2002 6:25 PM
Subject: [OSRS-PROJ] problems with ' and " in coordinates?
> Hi!
> I'm using PROJ to transform from lcc to lon,lat
> and I'm confused by the following:
> If I use:
> proj -I +proj=lcc +a=6378388.0000000000 +es=0.0067226700 +lat_0=40.0
> +lat_1=37.1780716667 +lat_2=42.8219283333 +lon_0=-3.687500  +x_0=600000.0
> +y_0=600000.0 +unfact=1.0000000000 <<EOF
> > 600000 600000
> > EOF
> I get the correct result:
> 3d41'15"W       40dN
> But if I use ' and " for the coordinates (i.e.,+lat_1=37d10'41.058"
> instead
> of +lat_1=37.1780716667 ), I get a wrong result:
> +lat_1=37d10'41.058"  +lat_2=42d49'18.9420"  +lon_0=-3d41'15"  +lat_0=40d
> <<EOF
> > 600000 600000
> > EOF
> 0dE     40dN
> As I understand from the man page, both notations
> are correct, where is the problem?
> Thanks
> Agus
> Dr. Agustin Lobo
> Instituto de Ciencias de la Tierra (CSIC)
> Lluis Sole Sabaris s/n
> 08028 Barcelona SPAIN
> tel 34 93409 5410
> fax 34 93411 0012
> alobo at ija.csic.es
> PROJ.4 Discussion List
> See http://www.remotesensing.org/proj for subscription, unsubscription
> and other information.
