[OSRS-PROJ] cs2cs and datum shift]
Duncan Agnew
agnew at bilby.ucsd.edu
Mon Aug 26 13:27:11 PDT 2002
A correction to my earlier posting (implicit in Prof. Mugnier's earlier
comment):
If the scale factor in the forward direction is sc, the scale factor
in the inverse should be
1.e6*(1.0 - 1./(1+(sc/1.e6)))
which means that, for example, a scale factor of 200 (ppm) needs -199.96
for the inverse. The forward/inverse test then does well even for such
larger values of sc.
Duncan Agnew
IGPP/SIO/UCSD
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
More information about the Proj
