[OSRS-PROJ] cs2cs and datum shift]
Duncan Agnew agnew at bilby.ucsd.edu
Mon Aug 26 09:33:23 PDT 2002
Roberto:
	This is not a bug, at least not a deep one.
	The problem is that you have applied the scaling parameter twice;
	if you set this (the 44 in the +towgs setting) to 0 there is no
	problem (inverse of forward is the original). So, it should be set
	to -44 in the inverse to give the right answer. Since a scale
	change (mostly) inflates the Earth, the problem shows up in the
	height.
	I do see errors in the forward/inverse pair as the scale factor exceeds
	50 ppm, but not for 44 ppm.
Duncan Agnew
IGPP/SIO/UCSD
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
