[OSRS-PROJ] Re: make geocentric XYZ one of proj's output choices
Clifford J Mugnier
cjmce at lsu.edu
Sun Dec 15 08:55:41 PST 2002
Frank,
Now if you use a 3x3 orthogonal rotation to a tanget or secant plane to the
ellipsoid and drop the third component, Z; you will have the ellipsoidal
implementation of the Polyhedric or Polyeder. There are topo sheets still
published on this ancient projection. (Sometimes called the Muffling).
Cliff Mugnier
LOUISIANA STATE UNIVERSITY
Dan Jacobson wrote:
> Can somebody enhance proj to make geocentric XYZ one of the output
> choices. It is used internally but it is a shame that one can't chose
> to output it.
Dan,
Because your wish is my command, I have incorporated geocentric coordinate
support in a form accessable to the end user. The fake projection
"geocent" may now be used with the pj_transform() function and the cs2cs
user program to define a coordinate system in geocentric coordinates.
The linear units are also applied to this geocentric coordinate system, but
prime meridians, x_0, y_0 and other non-ellipsoid parameters are ignored.
eg.
% ./cs2cs +proj=latlong +ellps=WGS84 +to +proj=geocent +ellps=WGS84
0 0
6378137.00 0.00 0.000
0 90
0.00 0.00 6356752.314
0 90 1000
0.00 0.00 6357752.314
Geocentric coordinates should not be used with the proj program as it
only operates in 2D. It is only for "real" projections.
I would encourage you to check out the latest PROJ.4 CVS source and test
the new facility as a "punishment" for requesting the feature.
PS. I will release a new version of PROJ.4 as soon as I am happy with my
updated translation of the EPSG 6.2.2 database to a PROJ.4 initialization
file.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam,
warmerdam at pobox.com
and watch the world go round - Rush | Geospatial Programmer for Rent
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
More information about the Proj
