[OSRS-PROJ] Instalation problem: libtool versions
Luís Mota
luis.mota at iscte.pt
Sun Dec 15 10:26:40 PST 2002
Hi Frank, everyone.
I'm having an installation problem similar to the one reported in
http://www.remotesensing.org/lists/proj_archive/msg00429.html . This problem
had a suggested solution in
http://www.remotesensing.org/lists/proj_archive/msg00430.html, which I
unfortunately could not understand...
There is some kind of libtool version problem. The libtool which is in my
system has version ltmain.sh (GNU libtool) 1.4 (1.920 2001/04/24 23:26:18)
but, as I run 'make' I get the following error:
/bin/sh ../libtool --mode=compile
gcc -DHAVE_CONFIG_H -I. -I. -I. -DPROJ_LIB=\"/usr/local/share/proj\" -g -
O2 -c PJ_aeqd.c
libtool: ltconfig version `' does not match ltmain.sh version `1.3.4'
Fatal configuration error. See the libtool docs for more information.
Has anyone seen this before? How can I solve this?
Bye and thanks, Luís Mota
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
More information about the Proj
