[OSRS-PROJ] Proj4 documentation
Paul Selormey paul at toolscenter.org
Sat Jun 15 20:12:11 PDT 2002
Hello Mike,
This is a good news. Proj4 is being used in many projects. Therefore updated
and current documentation is very much welcomed.
For the formats you wish to produce, I suggest you use LaTeX. You can get
dvi, pdf, ps outputs for free! Also, there are many converters to html and I
think xml (never used any).
Do you have access to the original documentation sources (not the pdf)?
Best regards,
Paul.
  ----- Original Message -----
  To: osrs-proj at remotesensing.org
  Sent: Sunday, June 16, 2002 3:48 AM
  Subject: [OSRS-PROJ] Proj4 documentation
  Hello,
  With Frank Warmerdam's kind permission, and after some email exchanges
with Gerald Evenden, I have volunteered to take over the documentation for
Proj4. Sadly, this does not mean there will be a new manual tomorrow, or
even the next day. It will take me some time to gather and integrate all the
current information. With a little luck, I hope to have something in place
by the fall. The new documentation sources will be placed in the proj4 cvs,
and will therefore be accessible to everyone. The intent is to produce pdf
output, probably html, and possibly xml. The exact toolset that will be used
is not definite yet. I am not planning any translations from English at this
point. You will be welcome and even encouraged to volunteer to translate
once the originals are in CVS.
  I welcome all your suggestions, comments, etc. Please email me at the
address below or email this list, clearly indicating in the subject line
that your message is for the proj4 documentation. Please don't mix
documentation comments with other types of comments, I may miss them in that
case.
  Thanks very much,
  Mike
  ________________________________________________________
  Mike Schmidt                        Systèmes Scientifiques SEPIA
  President                              SEPIA Scientific Systems
  Tel: 450-358-2266                  100 Richelieu, suite 2000
  Fax: 450-358-2267                 Saint-Jean-sur-Richelieu
  e-mail: mike at sepia.com        Québec, Canada J3B 6X3
  http://www.sepia.com            http://www.intello.com
  This email message is for the sole use of the intended recipient(s)
  and may contain confidential and privileged information.
  Any unauthorized review, use, disclosure or distribution is prohibited.
  If you are not the intended recipient, please contact the sender by
  reply email and destroy all copies of the original message.
  To reply to our email administrator directly, select the following
  <mailto:postmaster at sepia.com>
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20020616/731a95fd/attachment.html>
