[OSRS-PROJ] Proj4 documentation
Mike Schmidt mike at sepia.com
Sat Jun 15 20:44:42 PDT 2002
Hello, Paul
LaTeX will definitely be used. I was thinking more of what to use on top of
LaTeX. I have quite a few choices, including some of my own LaTeX based
systems. I'm afraid the original sources aren't currently available. I
won't have too much trouble ripping the text and images out of the pdfs. In
any case, all the current manuals have to be integrated together, and that
will mean reformatting the lot anyway. If anyone has a good system to
reproduce the graphics, I'd like to hear about it. Otherwise I'll use the
existing ones until I can do better.
When the time comes, I'll ask for volunteer reviewers.
Mike
At 12:12 PM 16/06/2002 +0900, Paul Selormey wrote:
>Hello Mike,
>This is a good news. Proj4 is being used in many projects. Therefore updated
>and current documentation is very much welcomed.
>For the formats you wish to produce, I suggest you use LaTeX. You can get
>dvi, pdf, ps outputs for free! Also, there are many converters to html and I
>think xml (never used any).
>Do you have access to the original documentation sources (not the pdf)?
>Best regards,
>Paul.
>----- Original Message -----
>From: <mailto:mike at sepia.com>Mike Schmidt
>To: <mailto:osrs-proj at remotesensing.org>osrs-proj at remotesensing.org
>Sent: Sunday, June 16, 2002 3:48 AM
>Subject: [OSRS-PROJ] Proj4 documentation
>Hello,
>With Frank Warmerdam's kind permission, and after some email exchanges
>with Gerald Evenden, I have volunteered to take over the documentation for
>Proj4. Sadly, this does not mean there will be a new manual tomorrow, or
>even the next day. It will take me some time to gather and integrate all
>the current information. With a little luck, I hope to have something in
>place by the fall. The new documentation sources will be placed in the
>proj4 cvs, and will therefore be accessible to everyone. The intent is to
>produce pdf output, probably html, and possibly xml. The exact toolset
>that will be used is not definite yet. I am not planning any translations
>from English at this point. You will be welcome and even encouraged to
>volunteer to translate once the originals are in CVS.
>I welcome all your suggestions, comments, etc. Please email me at the
>address below or email this list, clearly indicating in the subject line
>that your message is for the proj4 documentation. Please don't mix
>documentation comments with other types of comments, I may miss them in
>that case.
>Thanks very much,
>Mike
>________________________________________________________
>Mike Schmidt                        Systèmes Scientifiques SEPIA
>President                              SEPIA Scientific Systems
>Tel: 450-358-2266                  100 Richelieu, suite 2000
>Fax: 450-358-2267                 Saint-Jean-sur-Richelieu
>e-mail: mike at sepia.com        Québec, Canada J3B 6X3
>http://www.sepia.com            http://www.intello.com
>This email message is for the sole use of the intended recipient(s)
>and may contain confidential and privileged information.
>Any unauthorized review, use, disclosure or distribution is prohibited.
>If you are not the intended recipient, please contact the sender by
>reply email and destroy all copies of the original message.
>To reply to our email administrator directly, select the following
><mailto:postmaster at sepia.com>
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20020615/f08afed4/attachment.html>
