[OSRS-PROJ] Proj4 documentation
Norman, Jamie
jrnorman at aone-elexco.com
Mon Jun 17 07:35:55 PDT 2002
How do I get off of this group mail?
-----Original Message-----
From: Paul Selormey [mailto:paul at toolscenter.org]
Sent: Saturday, June 15, 2002 11:12 PM
To: osrs-proj at remotesensing.org
Subject: Re: [OSRS-PROJ] Proj4 documentation
Hello Mike,
This is a good news. Proj4 is being used in many projects. Therefore updated
and current documentation is very much welcomed.
For the formats you wish to produce, I suggest you use LaTeX. You can get
dvi, pdf, ps outputs for free! Also, there are many converters to html and I
think xml (never used any).
Do you have access to the original documentation sources (not the pdf)?
Best regards,
Paul.
----- Original Message -----
Sent: Sunday, June 16, 2002 3:48 AM
Subject: [OSRS-PROJ] Proj4 documentation
Hello,
With Frank Warmerdam's kind permission, and after some email exchanges with
Gerald Evenden, I have volunteered to take over the documentation for Proj4.
Sadly, this does not mean there will be a new manual tomorrow, or even the
next day. It will take me some time to gather and integrate all the current
information. With a little luck, I hope to have something in place by the
fall. The new documentation sources will be placed in the proj4 cvs, and
will therefore be accessible to everyone. The intent is to produce pdf
output, probably html, and possibly xml. The exact toolset that will be used
is not definite yet. I am not planning any translations from English at this
point. You will be welcome and even encouraged to volunteer to translate
once the originals are in CVS.
I welcome all your suggestions, comments, etc. Please email me at the
address below or email this list, clearly indicating in the subject line
that your message is for the proj4 documentation. Please don't mix
documentation comments with other types of comments, I may miss them in that
case.
Thanks very much,
Mike
________________________________________________________
Mike Schmidt Systèmes Scientifiques SEPIA
President SEPIA Scientific Systems
Tel: 450-358-2266 100 Richelieu, suite 2000
Fax: 450-358-2267 Saint-Jean-sur-Richelieu
e-mail: mike at sepia.com Québec, Canada J3B 6X3
http://www.sepia.com http://www.intello.com
This email message is for the sole use of the intended recipient(s)
and may contain confidential and privileged information.
Any unauthorized review, use, disclosure or distribution is prohibited.
If you are not the intended recipient, please contact the sender by
reply email and destroy all copies of the original message.
To reply to our email administrator directly, select the following
< mailto:postmaster at sepia.com>
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20020617/54f61288/attachment.html>
More information about the Proj
