[OSRS-PROJ] Proj4 documentation
Greg Morrison morrisong at cylabinc.com
Mon Jun 17 08:45:17 PDT 2002
Kick me off of this group, too.  I sent an email to the listserv, but I'm still getting email.  This group was helpful, but I am done with my project now...
  ----- Original Message -----
  To: 'osrs-proj at remotesensing.org'
  Sent: Monday, June 17, 2002 10:35 AM
  Subject: RE: [OSRS-PROJ] Proj4 documentation
  How do I get off of this group mail?
    -----Original Message-----
    From: Paul Selormey [mailto:paul at toolscenter.org]
    Sent: Saturday, June 15, 2002 11:12 PM
    To: osrs-proj at remotesensing.org
    Subject: Re: [OSRS-PROJ] Proj4 documentation
    Hello Mike,
    This is a good news. Proj4 is being used in many projects. Therefore updated
    and current documentation is very much welcomed.
    For the formats you wish to produce, I suggest you use LaTeX. You can get
    dvi, pdf, ps outputs for free! Also, there are many converters to html and I
    think xml (never used any).
    Do you have access to the original documentation sources (not the pdf)?
    Best regards,
    Paul.
      Sent: Sunday, June 16, 2002 3:48 AM
      Subject: [OSRS-PROJ] Proj4 documentation
      Hello,
      With Frank Warmerdam's kind permission, and after some email exchanges with Gerald Evenden, I have volunteered to take over the documentation for Proj4. Sadly, this does not mean there will be a new manual tomorrow, or even the next day. It will take me some time to gather and integrate all the current information. With a little luck, I hope to have something in place by the fall. The new documentation sources will be placed in the proj4 cvs, and will therefore be accessible to everyone. The intent is to produce pdf output, probably html, and possibly xml. The exact toolset that will be used is not definite yet. I am not planning any translations from English at this point. You will be welcome and even encouraged to volunteer to translate once the originals are in CVS.
      I welcome all your suggestions, comments, etc. Please email me at the address below or email this list, clearly indicating in the subject line that your message is for the proj4 documentation. Please don't mix documentation comments with other types of comments, I may miss them in that case.
      Thanks very much,
      Mike
      ________________________________________________________
      Mike Schmidt                        Systèmes Scientifiques SEPIA
      President                              SEPIA Scientific Systems
      Tel: 450-358-2266                  100 Richelieu, suite 2000
      Fax: 450-358-2267                 Saint-Jean-sur-Richelieu
      e-mail: mike at sepia.com        Québec, Canada J3B 6X3
      http://www.sepia.com            http://www.intello.com
      This email message is for the sole use of the intended recipient(s)
      and may contain confidential and privileged information.
      Any unauthorized review, use, disclosure or distribution is prohibited.
      If you are not the intended recipient, please contact the sender by
      reply email and destroy all copies of the original message.
      To reply to our email administrator directly, select the following
      <mailto:postmaster at sepia.com>
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20020617/a67f7b9b/attachment.html>
