[OSRS-PROJ] On Proj4...
Paul Selormey
paul at toolscenter.org
Thu May 30 07:28:42 PDT 2002
Hello Frank,
Thanks for the response.
> This is a mistake on my part. I will submit a bug (149) to myself to come
up
> with another strod() implementation with appropriate license constraints
or
> to rewrite my own version.
What is the specification or the true behavior that the VC++ does not
satisfy?
This way, I could also try my hand at it since I am working on the codes
now.
> static double ceval( struct PW_COEF *C, int n);
> Apparently in K&R C untyped arguments were implicitly integers.
Thanks. In fact, I picked my K&R C in bits and pieces :-) I was not lucky
enough
to use it :(
> I understand your rationale but I don't think I will incorporate your
"expanded
> macros" version into the core, even though I too find the macros sometimes
> obscure what is going on from the casual developer.
It is not an expanded macro version, but a replacement. I was hoping it will
take over
but it can still run in parellel. It is just a beginning of my work on the
projection, I hope
to work further on this even as I study map projections.
Best regards,
Paul.
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
More information about the Proj
