[OSRS-PROJ] Donald Elliptic Projection for AT&T V&H Coordinates?
Duncan Agnew agnew at bilby.ucsd.edu
Wed Nov 27 15:50:41 PST 2002
There is a description of this projection at
http://openmap.bbn.com/doc/api/com/bbn/openmap/util/VHTransform.html
(at the bottom of the page). The code used is open-source (it appears)
and can be downloaded; go to http://openmap.bbn.com/ for information.
The actual conversion code contained inside the Java is from other sources,
and it is clear that this is something that even AT&T had difficulty
sorting out later.
I leave it up to the more expert to add this to PROJ, and to reverse-
engineer the ellipsoid used.
Don't thank me, thank Google.
Duncan Agnew
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
