[OSRS-PROJ] Inverse function of a quadrant is wrong?
    Gerald I. Evenden
    gerald.evenden at verizon.net
    Wed Apr  9 13:36:58 PDT 2003
The ellipsoid inverse for PROJ.4 stereographic does seem to have
a problem in the equitorial and oblique modes.  I will look into
it and hopefully have a corrected version in a couple of days.
One note however, some of the example numbers used exceeded
90d latitude which should induce an error condition.  Also
the antipodal value should also yield an error for stereographic.
(Antipodal: coordinate in the opposite of the earth from
from the lat_0, lon_0 coordinate.)
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
More information about the Proj
