[OSRS-PROJ] Inverse function of a quadrant is wrong?
    Alexander Weidauer
    alex.weidauer at huckfinn.de
    Wed Apr  9 13:56:52 PDT 2003
Hi Gerald,
Ok I've tested it with other proj oringins but was confused by the
results. So I went back to lat_0=0, lon_0=0. I can test it for other
origins. The aim of my application is to show the usage of proj api
in an animation so I start to calculate NAN conditions for stere
initial origins. I want to create a animation over a moving origin
with a world map and a grid and render the image set.
Thanks Alex
Gerald I. Evenden schrieb:
> The ellipsoid inverse for PROJ.4 stereographic does seem to have
> a problem in the equitorial and oblique modes.  I will look into
> it and hopefully have a corrected version in a couple of days.
> One note however, some of the example numbers used exceeded
> 90d latitude which should induce an error condition.  Also
> the antipodal value should also yield an error for stereographic.
> (Antipodal: coordinate in the opposite of the earth from
> from the lat_0, lon_0 coordinate.)
> PROJ.4 Discussion List
> See http://www.remotesensing.org/proj for subscription, unsubscription
> and other information.
More information about the Proj
