[OSRS-PROJ] Horrors of --- Krovak projection
    Gerald I. Evenden
    gerald.evenden at verizon.net
    Fri Feb 14 07:54:32 PST 2003
I follow Lobochevski's rule: "Plagiarize!  Let nothing evade your eyes!
But please, let us call it research." (from old Tom Lehar song)
(please pardon possible misspellings). ;-)
I pulled down a copy of  proj-4.4.5.tar but did not find anything
about Krovak.  I presume this code is still on your "desk."
I would be glad to look at anything.  At the moment I nearly have
the rehacked code functioning but still in need of "refinements."
I was also working on a TeX/pdf of a writeup for Krovak that contains
the math in readable form---so far, the Czech site looks like the
only reliable source---at least it matches the code.
I would do a map but I don't have any vector data suitable for
medium scale European area showing current politics.
Because of getting the "long lost sources" back onto my current
machine due to Mike Schmidt's needs, I fell into a spasm of
doing some updates to PROJ.4.
On Fri, 2003-02-14 at 02:52, Frank Warmerdam wrote:
> Gerald I. Evenden wrote:
> > I did find someone's effort to translate it to PROJ form in C and
> > I am using that as a base *after* major surgery.  It came from
> > Thomas Flamming in thread:
> > http://remotesensing.org/lists/proj_archive/msg00306.html
> Gerald,
> Note that I have already incorporated the Krovak projection into the
> CVS version of PROJ.4 a month or so ago.  If you want to make improvements
> it would have been nice to work from that.
> I can't speak to the horrors of the internet though I am certainly
> responsible for propagating dodgy information on this and other projections
> on the GeoTIFF and PROJ.4 web sites.
> Best regards,
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
More information about the Proj
