[OSRS-PROJ] Projection Information Weather Satellite
Alexander Weidauer
alex.weidauer at huckfinn.de
Wed Oct 8 07:14:36 PDT 2003
Brayn,
I think that will not work with affine transforms
without having the right projection of the earh body
to the a plain sheet. Do you have a idea what they mean
with Oblique Horizon projection
it seems to be a photo where the satellite is turned
over the horizont normal. I think it could determined
if you have the trace coordinates of the satellite.
To program it it's to high for me and I have to grabb
deep into the proj library. I think you should write
Gerlad Everden. He is the creator of the library
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
More information about the Proj
