[OSRS-PROJ] Projection Information Weather Satellite
Ray Bryan E 2Lt 1 OSS/OSW
Bryan.Ray at langley.af.mil
Wed Oct 8 12:47:41 PDT 2003
Thanks Gerald,
Sounds like I need to do some reading on these proj4 options.
Bryan
-----Original Message-----
From: Gerald I. Evenden [mailto:gerald.evenden at verizon.net]
Sent: Wednesday, October 08, 2003 2:31 PM
To: osrs-proj at remotesensing.org; gerald.evenden at verizon.net
Subject: Re: [OSRS-PROJ] Projection Information Weather Satellite
There is proj=tpers (Tilted perspective). In addition to option h= there
are
tilt=<angle> and azi=<angle>
It is only for a spherical earth---which probably ought to be OK for scales
involved.
On Wednesday 08 October 2003 09:58 am, Ray Bryan E 2Lt 1 OSS/OSW wrote:
> Alex,
> Thanks for the information. According the NOAA, its is a GOES projection.
> (Geostationary Satellite). The satellite is in geosync orbit over -75
> Longitude and 0 degrees latitude. They have a fortran program they use to
> map to this projection. I think I will need to do some more research on
> this.
> Thanks again,
> Bryan
> From: Alexander Weidauer [mailto:alex.weidauer at huckfinn.de]
> Sent: Wednesday, October 08, 2003 10:15 AM
> Subject: RE: [OSRS-PROJ] Projection Information Weather Satellite
> Brayn,
> I think that will not work with affine transforms
> without having the right projection of the earh body
> to the a plain sheet. Do you have a idea what they mean
> with Oblique Horizon projection
> it seems to be a photo where the satellite is turned
> over the horizont normal. I think it could determined
> if you have the trace coordinates of the satellite.
> To program it it's to high for me and I have to grabb
> deep into the proj library. I think you should write
> Gerlad Everden. He is the creator of the library
> PROJ.4 Discussion List
> See http://www.remotesensing.org/proj for subscription, unsubscription
> and other information.
More information about the Proj
