[OSRS-PROJ] EPSG: invalid projections?
Jan-Oliver Wagner
jan at intevation.de
Fri Oct 10 09:28:12 PDT 2003
I've implemented a converter for the epsg file as delivered with
proj to a Thuban .proj file.
When loaded into Thuban there is an automatic test for each
projection and 4 of the 2480
seem to be incorrect. These are the error messages:
Error in projection "CH1903+ / LV95": lat_0 = 0 or 90 or alpha = 90
Error in projection "Bern 1898 (Bern) / LV03C": lat_0 = 0 or 90 or alpha = 90
Error in projection "CH1903 / LV03": lat_0 = 0 or 90 or alpha = 90
Error in projection "HD72 / EOV": lat_0 = 0 or 90 or alpha = 90
I've used proj 4.4.7.
Best
Jan
Jan-Oliver Wagner http://intevation.de/~jan/
Intevation GmbH http://intevation.de/
FreeGIS http://freegis.org/
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
More information about the Proj
