[OSRS-PROJ] EPSG: invalid projections?
Jan-Oliver Wagner
jan at intevation.de
Fri Oct 24 01:50:49 PDT 2003
got no feedback on this issue. The epsg file in CVS is still the same
as in proj 4.4.7.
For Thuban I will remove them.
On Fri, Oct 10, 2003 at 06:28:12PM +0200, Jan-Oliver Wagner wrote:
> I've implemented a converter for the epsg file as delivered with
> proj to a Thuban .proj file.
> When loaded into Thuban there is an automatic test for each
> projection and 4 of the 2480
> seem to be incorrect. These are the error messages:
> Error in projection "CH1903+ / LV95": lat_0 = 0 or 90 or alpha = 90
> Error in projection "Bern 1898 (Bern) / LV03C": lat_0 = 0 or 90 or alpha = 90
> Error in projection "CH1903 / LV03": lat_0 = 0 or 90 or alpha = 90
> Error in projection "HD72 / EOV": lat_0 = 0 or 90 or alpha = 90
> I've used proj 4.4.7.
Best
Jan
Jan-Oliver Wagner http://intevation.de/~jan/
Intevation GmbH http://intevation.de/
FreeGIS http://freegis.org/
PROJ.4 Discussion List
See http://www.remotesensing.org/proj for subscription, unsubscription
and other information.
More information about the Proj
